Date/Time: Fri, 19 Apr 2024 15:03:13 +0000
Chart Data Not Updating (delayed) - US Equities Feed
View Count: 631
[2021-04-05 14:16:26] |
User636370 - Posts: 18 |
Hi, I've subscribed to the US Equities feed. Signed releases. And, last week it looked like I was good to go. But today, I'm not receiving data again. It looks like I'm current on everything. No notices that I need to attend to anything. Within SC > File > Data/Trade Service Settings I have 'SC Data - All Services' selected. What am I missing? Thank you! |
[2021-04-05 16:36:58] |
John - SC Support - Posts: 30956 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-05 16:52:35] |
Thanks. I've followed the instructions, and the symbol used is 'CEMI' I sent the log file via the 'Send For Analysis' option within Message Log referencing this message thread. |
[2021-04-05 18:05:47] |
For some reason the Vendor of Record (barchart) has tagged you as a Professional, although you have only signed up for the Non-Professional feed. We are checking with them on this for you.
[2021-04-05 19:01:13] |
Ah, I see. Hopefully, I did not mistakenly sign disclosure as a 'Profissional Trader' thanks for your help on this! |
[2021-04-05 20:07:42] |
barchart has updated your status to Non-Professional, so you should be good now and receiving the real-time data for the U.S. Equities.
[2021-04-05 20:11:07] |
Excellent! You guys rock. Thanks again! |
