Date/Time: Fri, 29 Mar 2024 09:51:09 +0000
Removal of TT Trading Accounts from Sierra Chart Accounts for AMP Users
View Count: 9903
[2021-05-26 03:09:21] |
dubbs - Posts: 34 |
So, in post #43 in this thread above, does this mean that the SC CME Direct Routing service is up and running, or is post #43 referring to something different? I've read some of this thread and a few other threads on the Support Board and it's unclear to me if your CME Direct Routing thing is up and running or not? And if it is up and running, can I trade with SC using my AMP account and the SC CME Direct Routing service by following the instructions in post #43? Or what is the easiest most efficient way for me to trade with my AMP account using SC? Can you please clarify this for me? Thanks
Date Time Of Last Edit: 2021-05-26 12:20:07
[2021-05-26 13:45:53] |
John - SC Support - Posts: 30444 |
Post #43 is referencing a new method we have worked out with AMP to verify accounts. It is useful for those users that are not actively trading, but want to take advantage of the Non-Professional exchange fees for the CME Group. It is just an easier method to verify their futures trading account. It is NOT the CME Direct Order Routing. If you are actively trading from Sierra Chart, then you will be connected to your account and do not need to deal with the above solution. For information on the status of the CME Direct Order Routing, refer to this thread: Now Released: Upcoming CME Direct Routing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-26 14:06:24] |
dubbs - Posts: 34 |
Thank you. So there's still no way to trade with my AMP account using SC correct? I need to wait for the CME Direct Order Routing to be up and running, and then I can trade using SC with my AMP account, correct?
[2021-05-26 14:35:44] |
That statement is incorrect. You can use CQG with AMP and trade directly from Sierra Chart. If you want to use CQG, then once you are setup with AMP to use CQG, then follow these instructions to setup your Sierra Chart: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-27 02:52:03] |
dubbs - Posts: 34 |
OK thanks so much for clarifying everything.
[2021-06-20 00:57:21] |
Sierra_Chart Engineering - Posts: 13625 |
Regarding post #39 about EUREX trading connectivity, refer to this post: Now Released: Upcoming CME Direct Routing | Post: 269967 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-20 00:57:30
