Date/Time: Sat, 02 Jul 2022 23:20:49 +0000
How to Configure Drawing Tools Like Ray Lines and Parallel Ray Lines So they Extend to the Right
View Count: 710
[2014-03-03 15:13:00] |
User84202 - Posts: 3 |
On the chart below, you will see a Ray line and two parallel Ray Lines that are truncated and do not extend to the right towards infinity. http://www.sierrachart.com/image.php?l=1393859571699.png How can these ray lines be configured to extend to the right. The same question applies to the extended line tool. Date Time Of Last Edit: 2014-03-03 15:53:43
[2014-03-03 19:55:45] |
They are extending to the right. But they are getting clipped at the bottom edge of the Region Data Line along the top edge of the chart.
