Date/Time: Wed, 24 Apr 2024 06:51:59 +0000
Ofset setting for limit orders
View Count: 1072
[2014-02-20 14:35:49] |
GPST10 - Posts: 139 |
Hi I know there was offset setting somewhere for limit orders and I can't find now. Can anybody help me with this? One of my charts keeping offsetting and I don't need it. I think it was not the market moves but not sure. Thanks. |
[2014-02-20 14:38:40] |
Are you referring to Stop-Limit orders? If not, what Symbol are you trading? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-20 14:42:35] |
Using limit not stop limit and instrument was 6EH.
[2014-02-20 14:54:41] |
We have seen this issue with TransAct with that particular symbol. We can provide TransAct your email address and they can contact you. Would that work? They would need to see the log files and get some other details we assume from you, and it is best that the contact you directly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-20 14:54:57
[2014-02-20 14:56:02] |
No need its ok
[2014-02-20 14:57:28] |
OK, but we have seen this issue . Clearly it occurs at certain price level. Next time that you have this, we recommend contacting your broker about it and they can put you in contact with TransAct support.
