Date/Time: Thu, 25 Apr 2024 22:18:13 +0000
Coloring RSI if above or bellow a threshold
View Count: 1205
[2014-02-19 08:30:01] |
User11191 - Posts: 4 |
I would like to color the RSI study if it s above a certain threshold, and bellow. For example grey if between 30 and 70 and red if above 70, or green if bellow 30. I ve looked in the support board but I can t find anything exactly like this. Thank you |
[2014-02-19 09:00:43] |
This can be accomplished with the Color bar Based on Alert Condition study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s245 You will need 2 or 3 instances of the study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
