Date/Time: Thu, 28 Mar 2024 14:18:50 +0000
Parabolic SAR on close and price colored accordingly
View Count: 2152
[2014-02-19 07:25:06] |
User11191 - Posts: 4 |
I would like to know if Sierra can calculate the reversion of the parabolic sar study not on high/low of bars piercing the psar, but on close. If not how can I try to change the code of the original function in Sierra to do this? Would it be beyond a normal end user possibilities? I would also like to know how can I color the price bars if the psar study is bellow price or above. Incredible program the Sierra Team has developed, congratulations. Thank you very much, my best regards. |
[2014-02-19 08:26:04] |
Color bar based on above/bellow study - I ve found a way to color price bars if they are above or bellow the PSAR. This method will work, just add this function to the chart
Date Time Of Last Edit: 2014-02-19 08:26:33
[2014-02-19 18:16:08] |
The code can be modified. The documentation for this is here: http://www.sierrachart.com/index.php?l=doc/doc_BuildCustomStudiesDLL.html You can find the parabolic study in this file: /ACS_Source/Studies.cpp file in the folder that Sierra Chart is installed to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-19 18:18:33
