Date/Time: Fri, 19 Apr 2024 20:35:52 +0000
Spread between 2 weighted moving aerages
View Count: 1047
[2014-02-18 20:15:45] |
User99819 - Posts: 2 |
I am trying to make a/show a spread between 2 moving averages. It will be shown as a histogram and the colors will change rising/falling
spread.jpg / V - Attached On 2014-02-18 20:15:25 UTC - Size: 336.08 KB - 416 views Attachment Deleted. |
[2014-02-19 04:09:09] |
Sawtooth - Posts: 3975 |
Use the Study Subgraphs Difference study, set the Draw Style to Bar, set the Auto-Coloring to Based On Slope
[2014-02-19 08:05:19] |
Have a look at the Moving Average Difference study: http://www.sierrachart.com/image.php?l=1392797036887.png We updated it in version 1094 to support the Moving Average Type input, so you can use a Weighted average Update Sierra Chart by selecting Help >> Download Current Version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-19 08:05:45
[2014-02-19 15:29:13] |
I updated to newest version, found moving ave. diff, When I set it to weighted and hit OK, it reverts back to simple MA, could you check please. Thanks |
[2014-02-19 18:02:40] |
Remove the study from the chart and add it again. It should keep the Moving Average Type you are using.
