Date/Time: Thu, 25 Apr 2024 13:45:33 +0000
Now Available: Binance Data Feed!
View Count: 18917
[2021-02-16 10:30:05] |
Regarding the depth issue described in post #67, we now know what the reason for this is. And why we could not reproduce it previously. It relates to when using a relatively small number for this setting and there is a significant and fast change in price: This issue is now resolved. Update to prerelease version 2231 or higher.
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxDepthLevels For now set that to 0 until we determine a solution. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-17 01:59:16] |
User425160 - Posts: 15 |
Would it be possible to execute order straight from Sierra Chart platform or is it just data only?
[2021-02-17 03:01:15] |
For Binance it is just market data only.
[2021-02-27 13:13:11] |
01110010 - Posts: 33 |
The Binance Futures API has an Endpoint for intraday Open Interest data. It would be brilliant if it was possible to get this into Sierra for the Binance Futures symbols.
[2021-03-31 16:18:51] |
nach1321 - Posts: 12 |
With Bitmex being excluded for those in US and Binance being market data only, do you have any plan for supporting trade routing for US (other than your planned decentralized exchange)? Is there a way to rout orders via API to something like Coinbase?
[2021-04-06 05:53:09] |
Due to the large amount of trading on Binance, we have had to change the Intraday Data Storage Time Unit for the historical data on our servers to 1 Second instead of tick by tick for Binance. We are also moving the Binance data files to dedicated drives. And compressing the existing data. We will have this completed in the next couple of days. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-06 05:53:28
[2021-04-06 06:08:43] |
samual sprat - Posts: 343 |
Please enable order execution from Sierra chart for binance futures and spot. There is a lot of interest for this. Would be highly appreciated
[2021-04-16 08:45:51] |
User734143 - Posts: 1 |
We are also moving the Binance data files to dedicated drives. And compressing the existing data. We will have this completed in the next couple of days. Hello. This is my subjective opinion. When information is compressed without the possibility of its recovery, there is an inevitable loss of information for making trading decisions. Is it possible to delay the application of the compression algorithm to 1 second for at least 24 hours? Thanks. |
[2021-05-08 16:35:56] |
olufemig - Posts: 5 |
Would be great if we can execute binance orders on SC
[2021-05-20 08:00:55] |
smeb - Posts: 10 |
Hello, When I look at yesterday (19th may) price for BTC/USDT-BINANCE, the lowest is around 34K. On Binance, and on tradingview.com (binance feed) it's showing 30K. This is a big difference. Is this a setting problem on my side or is this due to your "1 second" instead of tick by tick issue ? Regards, |
[2021-05-20 13:50:36] |
John - SC Support - Posts: 31098 |
We can't say exactly what is happening in the case you are stating, but Binance has been having issues with their data feed lately.
[2021-05-21 02:38:51] |
User32628 - Posts: 15 |
For me the data had been updating pretty well, although I also notice some missed highs and lows (which I can understand and work with), just geting the data and being able to use SC capabilities with it is amazing. The last couple of days though, Binance data doesn't update or come in at all for me. Any idea what is going on or is there anything on my end I can try?
[2021-05-24 14:17:44] |
There really isn't anything that can be done. This is due to how Binance has their data feed.
[2021-10-14 20:43:22] |
User379468 - Posts: 508 |
Is there any reliable datafeed for Crypto usable in SC to use for analysis in trading on an exchange like FTX?
[2022-03-27 08:56:11] |
User365411 - Posts: 173 |
Is the Historical Market Depth (past days backfill) actually available for Binance feed? If not, will it be implemented in the near future or will it never be? TY |
[2022-06-10 07:49:09] |
Hi, I noticed a data error in the BTCUSDT_PERP_BINANCE symbol that appeared today, there is a clear data error with a giant price wick down to 22k - can this be retroactively fixed/removed or will we just have to ignore it? thanks |
[2022-06-10 14:13:08] |
01110010: The first thing to do is to go back to before where that bad data is located and right click and select Delete and Download Data. This will delete all the data forward from that spot and redownload it. If the error persists, then that is what we are getting from the exchange. If you want to edit it, you can do so by selecting Edit >> Edit/Download Data - Intraday Chart and find the particular trade that is causing the issue and adjust it. Refer to the following: Edit Menu: Edit >> Edit/Download Data - Intraday Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-14 15:07:05] |
User328277 - Posts: 1 |
Hello. There are delays in receiving data, which can be up to several minutes.
[2022-12-23 08:47:14] |
User653970 - Posts: 38 |
I have problem with Binance futures data that Sierra Chart only receive data whenever I do Delete and Download Data. Rather than that, no real-time data updates.
[2022-12-23 15:44:24] |
We checked a couple of Binance symbols and we are not seeing an issue. What symbol are you using for which you are seeing a problem?
