Date/Time: Sat, 20 Apr 2024 09:14:01 +0000
Alignment not coming out with Text Tool and ACSIL
View Count: 1108
[2014-02-17 06:17:19] |
onnb - Posts: 660 |
I am formatting a string with padding so that it is right justified. See below what the SCString looks like before setting the tool text field. Now when I see it on the chart, it looks like the link below. Note that the fields are no longer aligned. Does this make sense? Am I missing a setting to the tools object or something? SCString Upcoming Events USD Monday 08:01 Holiday Bank Holiday USD Wednesday 08:30 High PPI m/m USD Wednesday 08:30 High Building Permits USD Wednesday 14:00 High FOMC Meeting Minutes USD Thursday 08:30 High Unemployment Claims http://www.sierrachart.com/image.php?l=1392617718832.png Date Time Of Last Edit: 2014-02-17 06:18:02
[2014-02-17 06:31:03] |
The basic reason that you see what you do is that your source code editor is probably using a fixed width font and the font setting in Sierra Chart is a variable width font. The only way to get guaranteed alignment is to output each column separately. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
