Date/Time: Fri, 19 Apr 2024 00:02:21 +0000
Using keyboard to change period to weekly bars
View Count: 984
[2014-02-17 03:02:59] |
joshtrader - Posts: 438 |
I can type "1d" to switch to a daily chart, "5m" to switch to a 5 minute chart, and so on. But typing "1w" does not change to a weekly chart--instead it seems to change symbols. Can it be made so that "1w" changes to a weekly chart?
[2014-02-17 03:40:07] |
No. You need to use a standard keyboard shortcut for the Chart >>Bar Periods >> Weekly menu command: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSettingsMenu.html#CustomizeKeyboardShortcuts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
