Date/Time: Thu, 25 Apr 2024 03:41:46 +0000
Running Multiple Instances Of Sierra On Multiple Computers
View Count: 2326
[2020-09-16 13:09:21] |
User991052 - Posts: 30 |
Hi Support, Is is permissible to run " two " independent instances of Sierra simultaneously on seperate computers w/ my data/trade service? i.e Denali Data Feed (Realtime) / Sierra Order Routing (TT) Regards, |
[2020-09-16 15:11:30] |
John - SC Support - Posts: 31098 |
Yes, this is possible, but you will have to pay the exchange fee a second time to get the data to that second computer. Refer to the information here: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-16 19:38:39
[2020-09-17 01:39:29] |
User372626 - Posts: 59 |
I have two computers,one for tradering using Denali+TT and one for reading market data.How should I set it up and how should I pay?Thanks.
[2020-09-17 14:02:01] |
If you have not already done so, then install Sierra Chart on the second computer. You will use the same Account Name and password to login to both. Set up your Denali Exchange Data Feed to allow for two computers simultaneously. The instructions are given in the link above, here it is again: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously On the second system, go to File >> Data/Trade Service Settings and set the "Service" to SC Futures Order Routing/Data. On that same page, ensure that the option for Allow Support for Sierra Chart Data Feeds is enabled (checked). Setup the options for this service in the same way as your other system. You will want to set this up this way so that you will use the same Symbols for both installations. You could then place trades from this other computer as well, but you do not need to. Just do not enable trading from this second computer. That is it. Just open a chart for a CME Group symbol and you will be getting the live data for that symbol on that second computer. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-17 15:01:41] |
Can I close the trading account on the second computer and just look at the market data?
[2020-09-17 15:36:32] |
If you do not mind having different symbols between the two computers, then just leave the Data/Trade Service Settings >> Service to SC Data - All Services on that second computer. And as long as you do not set Sierra Chart to connect to a Trading service, then you will not be able to trade from that second computer. It is your choice on which way you want to do it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-18 06:39:18
[2020-09-17 16:01:59] |
Merlin - Posts: 81 |
User372647 - when you say "look at the market data", do you need to look at it in real time? Or would it be sufficient for your purposes to only see historical or 10-minute-delayed data on the second instance? If delayed data is acceptable on instance 2, you don't need to pay the 2nd exchange fees.
[2020-09-18 09:32:05] |
To use the Delayed Exchange Data Feed, refer to: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
