Date/Time: Fri, 29 Mar 2024 08:43:43 +0000
Import trade fills to view in Sierra Charts
View Count: 534
[2020-09-07 22:08:03] |
Yes, you can do this but the format has to be correct. Refer to the information here: Trade Activity Log: Importing and Exporting Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
