Date/Time: Thu, 10 Sep 2026 06:51:39 +0000
Numbers Study Font Size
View Count: 1449
| [2014-02-03 04:39:32] |
| User94740 - Posts: 333 |
Hi SC, is it possible to configure the software to increase the font size of the numbers after increasing the volume multiplier? It is hard to understand why the numbers would get even smaller when increasing the volume mutliplier, because there should be more room than for the numbers.
| [2014-02-03 05:32:33] |
This makes no sense. What volume multiplier you setting exactly? And you are saying you notice a change with the font size used within Numbers Bars when you change the volume multiplier? Provide images of this.
