Date/Time: Fri, 29 Mar 2024 07:27:28 +0000
Delayed Data
View Count: 519
[2020-07-22 07:47:31] |
Sudhirc - Posts: 50 |
Hello, How long will i get free trial to evaluate service package 5? Since i want to use Delayed Data, my understanding is there will be no Exchange fees, however are there any data feed costs?? thank you. |
[2020-07-22 17:30:08] |
Your usage time Ending Date: 2020-08-03 Follow these instructions to add usage time to your Sierra Chart account:
1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access however are there any data feed costs?? You only need Service Package 5:Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-22 17:30:18
