Date/Time: Fri, 19 Apr 2024 10:04:29 +0000
snap tool
View Count: 1547
[2014-01-30 11:49:29] |
AKR - Posts: 523 |
is there a way to always have the snap to high/low on. what I mean is can I set a line in a way, that it automatically snaps to eg high of a bar close to it when I start or finish with the drawing. without need of twice clicking right on drawing and telling it to snap? thx!! |
[2014-01-30 16:40:22] |
Yes. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#Snapping Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
