Date/Time: Fri, 19 Apr 2024 21:45:08 +0000
[User Discussion] - IB Sierra and BT
View Count: 1464
[2014-01-30 09:17:54] |
jaban - Posts: 66 |
Hi I use Sierra chart with Bracket trader front trading Both sides have an update link for IB When I use the Sierra link my BT doesnot work anymore When I use the BT link sierra is not working properly , the access signals keeps going on and off Your wisdom is asked thanks jaban |
[2014-01-30 10:12:33] |
You need to use Trader Workstation 9392 or higher for Sierra Chart. This is all we can say.
[2014-01-30 11:02:01] |
jaban - Posts: 66 |
You need to use Trader Workstation 9392 or higher for Sierra Chart My TWS = Build 943.1c jan 6 2014 I guess this is the latest version cannot find the 9392 number Do I have the correct version thks |
[2014-01-30 11:10:34] |
Yes. Not quite sure where we got the number 9392. It was somewhere on Interactive Brokers website or somewhere within TWS itself. 9392 obviously is equivalent to 939.2.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-30 11:14:44
[2014-01-30 11:16:40] |
The version number was previously posted on this page: https://www.interactivebrokers.com/en/index.php?f=674 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-30 18:02:05] |
jaban - Posts: 66 |
Hi Can you tell me which API version Sierra is using please |
[2014-01-30 18:17:56] |
We do not use the Interactive Brokers API. Sierra Chart connects directly to Trader Workstation.
