Date/Time: Fri, 29 Mar 2024 11:18:45 +0000
My Reversals doesn't work
View Count: 1263
[2014-01-28 11:42:01] |
User57878 - Posts: 24 |
HI, I'm backtesting a system with the spreadsheet systems. This is a crossover system, giving arrows up and down for buy sell signals. I'm automating it with spreadsheets. I want any opened order to be closed when an opposite signal is trigerred. I tried to allow this with the spreadsheet study inputs, but it doesn't work. Maybe i done something incorrectly. Attached, you can see the settings i used in the inputs, and the chart. On the chart, you see sell orders triggered with the arrow, then buy signals coming, but they are not triggered. Maybe they just close the sell orders. Stop Loss is not wide too, so maybe it's just the SL hit. Want i want is that any opposite signal close the current order, and open its trade. I don't want to use the buy exit and sell exit columns in the spreadsheet. Thanks for the help. |
3f6c3d89e8fe9a007993a592fb6d2ce4.png / V - Attached On 2014-01-28 11:41:31 UTC - Size: 103.78 KB - 343 views |
[2014-01-28 16:35:57] |
Up! Help please ?
[2014-01-28 16:56:40] |
Sawtooth - Posts: 3952 |
Set 'Allow Entry With Working Orders' to Yes Set 'Allow Opposite Entry With Opposing Position Or Orders' to Yes |
[2014-01-28 17:08:38] |
Marvelous! working! thanks a lot
[2014-01-28 17:39:09] |
We can only refer you to the relevant documentation. You will need to study the the related automated trading functionality further. Refer these two sections here: http://www.sierrachart.com/index.php?l=doc/doc_AutoTradeManagment.php http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#IgnoredSignals Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-29 15:49:08] |
