Date/Time: Fri, 19 Apr 2024 14:12:49 +0000
How to change Chart Background color according to time
View Count: 4168
[2014-01-28 15:03:55] |
jackw - Posts: 57 |
Use the 'Color Background Based on Alert Condition' study. On the Alerts tab, enter a formula like the following: OR(BARTIME < 9.5/24 ,BARTIME >= 16.5/24) Replace 9.5 (9:30am) and 16.5 (4:30pm) with your stop and start times. To apply different background colors to different periods, add the study multiple times. |
[2014-01-28 16:01:46] |
User16114 - Posts: 153 |
The study "Time Range Highlight" is another option.
[2014-01-28 16:59:35] |
We recommend using the Time Range Highlight study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s278 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
