Date/Time: Thu, 25 Apr 2024 17:45:39 +0000
Old std IB data and New Data Feed
View Count: 1023
[2014-01-27 23:10:50] |
HalGE - Posts: 39 |
I have the new data feed and it seems to work very well, but this is happening... I start the IB TWS and then start Sierra Charts and so far the futures symbols I use are ok... ES...YM...NQ..a few others What is a problem is the interday TICK-NYSE-I-NYSE chart... all I get are the bars above the zero line... ( this symbols data ranges from +1200 down to -1200 I also notice that the futures symbols have that [M] but the Tick does not.. I figgered that it was connected to the TWS...well, maybe it is half connected.. What do I do now?? Thanks Hal |
[2014-01-27 23:31:23] |
Use the Sierra Chart $TICK symbol which you can find in File >> Find Symbol >> Market Stats.
