Date/Time: Thu, 25 Apr 2024 22:20:13 +0000
New User, question about the amount of historical data included with SC
View Count: 1083
[2014-01-27 22:26:09] |
Auspicatum - Posts: 46 |
Hello !, As stated previously, I am new to Sierra Charts. I do really like it so far though, and the pricing is reasonable. My question is about the amount of data that is available with SC. I am still on the free trial. I read through most all of this website, and I found one place that stated that SC has "detailed data that goes back to about 2007"(?? It was somewhere around there, maybe 2005?) . Anyway, when I load Forex data, for EURUSD for example, the furthest back date is 5/3/2011 which is not close to what was stated in this website. So, I figure that I am not loading the data correctly perhaps? By the way... it is "intraday data" that we are discussing here. If I understand the process correctly, one can not load any more data then what is noted in the "file size". And that is the most distant date. So , please could you explain this to me, and help me to get data from further back. I am quite sure that I will be purchasing this software for further use...but I need to work out these questions first. Thanks. (also, does Tradestation data work on Sierra Charts?) Thank you for your time, And hopefully I will here back from you very shortly. |
[2014-01-27 22:49:54] |
To get data that goes further back, refer to help topic 42.1: http://www.sierrachart.com/index.php?l=doc/helpdetails42.html#h42.1 Sierra Chart does not support trade station data directly, however you can import data that is in a text format: http://www.sierrachart.com/index.php?l=doc/doc_TextCSVDataFormat.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-27 22:51:07
