Date/Time: Thu, 25 Apr 2024 00:37:35 +0000
Current date not visible on TPO chart
View Count: 916
[2020-06-21 21:23:00] |
When you remove the study from the chart do you see the June 19 data in the chart?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-21 21:23:06
[2020-06-26 05:03:49] |
Well, you must be able to see the standard chart bars when you remove the TPO Profile Chart study. Unless the Graph Draw Type is set to Blank. What we want you to do is to duplicate that chart: Chart Menu: Duplicate Chart (Chart menu) On the duplicated chart, remove all studies. You should then see the standard chart bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-26 20:23:42] |
Refer to this section here: Time Price Opportunity (TPO) Profile Charts: TPO Chart Time Scale (TPO Chart Time Scale) The last paragraph explains why you are probably seeing what you do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-26 20:24:03
[2022-09-16 14:37:20] |
cybersmart - Posts: 1 |
My TPO chart not showing today date column. Today September 16th and it shows September 15th data.
[2022-09-16 15:43:52] |
Sierra_Chart Engineering - Posts: 14076 |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
