Date/Time: Thu, 25 Apr 2024 12:09:41 +0000
no data feed from oec
View Count: 1142
[2014-01-27 14:21:13] |
User36188 - Posts: 6 |
I signed up for 3 more months last night and have no connection for data feed from OEC..no change from my end when i extended for 3 more months.
[2014-01-27 16:57:24] |
You need to install version 1078. It can be downloaded with this link: http://www.sierrachart.com/downloads/1078SierraChartSetupPrerelease.exe That version will connect to OEC. With version 1081 that you are running, the connection is not supported because we are working on changes to the connection method to OEC. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
