Date/Time: Thu, 25 Apr 2024 21:46:28 +0000
I don't want to update!
View Count: 1604
[2021-07-28 15:09:17] |
We confirmed it is resolved. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings However, we can see that version is locked out. We need to look into that. To see if that was is something we recently set. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-28 15:12:16
[2021-07-29 05:08:43] |
Sierra_Chart Engineering - Posts: 14090 |
We made a mistake, in your case version 1957 is not locked out. Only when using the Denali data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-29 13:31:24] |
Matt654 - Posts: 73 |
Its okay now, it suddenly started working early yesterday.
