Date/Time: Sat, 20 Apr 2024 08:20:23 +0000
Feature Request - Any supporter?
View Count: 1117
[2014-01-25 21:09:50] |
User43169 - Posts: 4 |
Dear Sierra chart, There's one feature that I think is missing to my trader's happiness. I'm pretty sure can easily be done, but then again, as a software developer, I know... what can be easily be done? I would find very useful to add a "Note" field at each drawing. So, If on a chart I have 5 fibs retracements and I open the "manage chart drawing" window I have no way to know which is which or why did I created it few weeks ago. Obviously a note field would help keep track. Likewise for line, boxes, arrows etc... I hope other users will share my views and therefore help create a useful feature. Thanks for your good work, Carol |
[2014-01-26 05:54:35] |
SgtJ - Posts: 154 |
For lines, rectangles, etc right click it and select modify text. For fibs guess you just gotta keep the drawn line visible or use the type text tool.
[2014-01-27 23:06:24] |
We will have to see about this later on. We really have a lot of other higher priorities.
