Date/Time: Sat, 20 Apr 2024 02:27:17 +0000
Spreadsheet Functions IF errors
View Count: 1107
[2014-01-25 17:31:23] |
yoytu - Posts: 59 |
Format: IF(Condition, TrueValue, FalseValue)
a simple =if(A1>A2,1,0) give invalid formula
Evaluates the condition and returns the TrueValue if the condition evaluates to TRUE or the FalseValue if it evaluates to FALSE. |
[2014-01-26 21:39:18] |
vegasfoster - Posts: 444 |
That should work, did you figure it out? If not, can you post a pic?
[2014-01-26 21:48:25] |
Rather than the comma delimiter you probably need to use a semicolon delimiter based upon your region.
