Date/Time: Sat, 20 Apr 2024 12:06:17 +0000
Apply Daily OHLC study to weekly chart....help
View Count: 1124
[2014-01-25 09:23:04] |
Meritus - Posts: 164 |
Is there a way to configure the Daily OHLC study so that I can apply it to a weekly chart? Is there a weekly version of this study? Thanks in advance |
[2014-01-25 16:38:55] |
mkata - Posts: 103 |
Try using the study Previous OHLC-Variable Period. I think this has the functionality you're looking for.
[2014-01-25 20:57:25] |
What is the purpose of applying a study like the Daily OHLC study to a weekly chart? Each weekly bar shows you exactly what you need without applying another study showing you what the OHLC values are.
