Date/Time: Thu, 28 Mar 2024 08:33:59 +0000
Amp/TTnet with SC
View Count: 1129
[2014-01-24 20:42:25] |
bwalks123 - Posts: 122 |
Hi guys I am having major issues getting TTnet setup. Does Xtrader/TTnet need to be running while sierra chart is open to receive the feed? not sure how it all works. |
[2014-01-24 21:22:49] |
No. Do you have your AMP / TT Net connection details? If so, we can use remote assistance and help you get connected assuming the information is valid.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-24 21:23:15
[2014-01-25 00:15:54] |
I actually just figured it out an am connected. As far as the DOM and keeping up during news events is there a settings to keep the data feed smooth and quick for the market depth and recent bid ask volume columns? I am subscribed to SC real time and historical bid ask data feed as well.
[2014-01-25 00:57:07] |
Do you mean you do not notice it is already smooth and quick? When you look on the title bar of the chart or Trade DOM do you see a [M] indicator after the symbol.
[2014-01-25 04:44:28] |
Its was running smooth for the little bit i had it up and running but I saw somewhere on the support board where someone said they changed some millasecond interval settings to produce the quickest delivery of data feed?
[2014-01-25 09:49:09] |
They are referring to the Chart Update Interval: http://www.sierrachart.com/index.php?l=doc/doc_GeneralSettings.html#CUI Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
