Date/Time: Wed, 24 Apr 2024 22:44:43 +0000
OEC connectivity with version 1083
View Count: 1569
[2014-01-24 14:38:26] |
ejtrader - Posts: 688 |
SC Team - Is the connectivity to OEC works(not the data - but just the connectivity) is expected to work with OEC? For some reason - with FIX the connection doesn't work. (old sc version works). Thanks Open E Cry FIX/FAST - Connecting to trading server: sim.openecry.com:9400. | 2014-01-24 08:37:02 Resolved address sim.openecry.com to IP 64.94.37.207 | 2014-01-24 08:37:02 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2014-01-24 08:37:23 OEC FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2014-01-24 08:37:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-24 08:37:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-24 08:37:23 Disconnected from Open E Cry. | 2014-01-24 08:37:23 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-24 08:37:23 File >> Disconnect selected. | 2014-01-24 08:37:27 Disconnected from Open E Cry. | 2014-01-24 08:37:27 |
[2014-01-24 17:26:12] |
We have asked OEC to support FIX on the simulation server. We do not have a response yet on this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-28 16:43:38
[2014-01-28 16:31:18] |
SC team - Wondering if OEC got back to you on this. Thanks |
[2014-01-28 16:43:14] |
Yes. Connecting to the OEC simulation server is now supported with FIX. It always was supported but it required a non-SSL connection.
[2014-01-28 17:24:07] |
Would you please paste how the connection needs to look like? I have tried with 1085 and unable to connect. Please note that I am only trying to get a connection and aware that data is not yet supported. Thanks Open E Cry FIX/FAST - Connecting to trading server sim.openecry.com:9300. | 2014-01-28 11:23:22 Resolved address sim.openecry.com to IP 64.94.37.207 | 2014-01-28 11:23:22 The network socket is connected. | 2014-01-28 11:23:22 OEC FIX Trading session: Sending the Logon message. | 2014-01-28 11:23:22 Open E Cry FIX/FAST: Connected to trading server. | 2014-01-28 11:23:22 Open E Cry FIX/FAST: Connecting to FAST market data server: sim.openecry.com:9301. | 2014-01-28 11:23:22 Resolved address sim.openecry.com to IP 64.94.37.207 | 2014-01-28 11:23:22 The network socket is connected. | 2014-01-28 11:23:22 OEC FAST Market Data session: Sending the Hello message. | 2014-01-28 11:23:22 OEC FAST Market Data session: Sending the Logon message. | 2014-01-28 11:23:22 OEC FAST Market Data session: Received an unexpected Hello message. | 2014-01-28 11:23:22 OEC FAST Market Data session: Sending a Logout message. Text = Unexpected Hello message. | 2014-01-28 11:23:22 OEC FAST Market Data session: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2014-01-28 11:23:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-28 11:23:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-28 11:23:22 OEC FIX Trading session: Sending a Logout message. | 2014-01-28 11:23:22 Disconnected from Open E Cry. | 2014-01-28 11:23:22 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-28 11:23:22 OEC FIX Trading session: Received a Logout message. | 2014-01-28 11:23:23 OEC FIX Trading session: Logged out and disconnected. | 2014-01-28 11:23:23 Open E Cry FIX/FAST - Connecting to trading server sim.openecry.com:9300. | 2014-01-28 11:23:27 Resolved address sim.openecry.com to IP 64.94.37.207 | 2014-01-28 11:23:27 The network socket is connected. | 2014-01-28 11:23:28 OEC FIX Trading session: Sending the Logon message. | 2014-01-28 11:23:28 Open E Cry FIX/FAST: Connected to trading server. | 2014-01-28 11:23:28 Open E Cry FIX/FAST: Connecting to FAST market data server: sim.openecry.com:9301. | 2014-01-28 11:23:28 Resolved address sim.openecry.com to IP 64.94.37.207 | 2014-01-28 11:23:28 The network socket is connected. | 2014-01-28 11:23:28 OEC FAST Market Data session: Sending the Hello message. | 2014-01-28 11:23:28 Buffered socket caught an unhandled exception from the owner OnBufferedSocketReceivedData in OnRead. | 2014-01-28 11:23:28 Date Time Of Last Edit: 2014-01-28 17:26:16
sc_OEC_Fix.jpg / V - Attached On 2014-01-28 17:22:40 UTC - Size: 106.85 KB - 334 views |
[2014-01-28 17:35:02] |
There is a problem we can see with the connection and we need to look into it.
[2014-01-29 06:29:27] |
Please test connecting to OEC using version 1086 and let us know if there any problems.
[2014-01-29 06:42:14] |
SC Team - 1086 - works fine as expected. I mean - I have only tested connectivity function. Thanks Date Time Of Last Edit: 2014-01-29 06:46:49
[2014-01-29 07:26:42] |
OK this is good.
[2014-01-29 15:05:02] |
With OEC - I am using SIM account. SC(1086): - price updates OK - depth update issues (image attached) - When force reconnected - depth updates work for few seconds but immediately the same issue repeats. OEC direct platform: - Price updates OK - depth updates OK Thanks Date Time Of Last Edit: 2014-01-29 15:11:20
SC_OEC_Depth.jpg / V - Attached On 2014-01-29 15:02:49 UTC - Size: 29.03 KB - 393 views |
[2014-01-29 16:19:26] |
We did become aware of the market depth issue last night. We have to think about how to solve it. OEC apparently is not sending through delete messages as documented.
