Date/Time: Fri, 29 Mar 2024 10:45:27 +0000
Delayed data with denali
View Count: 726
[2020-06-02 19:05:24] |
User303735 - Posts: 9 |
I just got my new data with denali, my broker is AMP. But my data appears delayed all the time and my trade service settings setup is all correct. Could you please solve this problem? i have already 2 days problems with data denali and AMP advice me to ask you directly. Thank you
[2020-06-02 19:20:21] |
Can you tell us what symbol is delayed. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-02 19:31:28] |
The symbol delayed is the ES. I have enable CME data
[2020-06-02 19:47:12] |
Software version: 2115 64-bit | 2020-06-02 21:39:07.536 Primary Thread ID: 6644 | 2020-06-02 21:39:07.536 Enabled for: Advanced Features 2. | 2020-06-02 21:39:07.536 Enabled for: Sierra Chart Historical Data Service. | 2020-06-02 21:39:07.536 Enabled for: Denali Real-Time Exchange Data Feed. | 2020-06-02 21:39:07.536 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-06-02 21:39:07.536 Enabled for exchange2: CME | 2020-06-02 21:39:07.536 Allow Support for Sierra Chart Data Feeds is disabled. | 2020-06-02 21:39:07.536 Current selected Data/Trading service: SC Futures Order Routing/Data | 2020-06-02 21:39:07.536 Custom symbol settings values: disabled | 2020-06-02 21:39:07.536 Chart Update Interval: 500 | 2020-06-02 21:39:07.536 Intraday Data Storage Time Unit: 0 | 2020-06-02 21:39:07.536 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2020-06-02 21:39:07.536 2020-06-02 21:39:07 Local computer time | 2020-06-02 21:39:07.536 2020-06-02 19:39:07 Local computer time in UTC | 2020-06-02 21:39:07.536 2020-06-02 21:39:07 Local computer time in SC Time Zone | 2020-06-02 21:39:07.536 2020-06-02 19:25:28 Server time in UTC | 2020-06-02 21:39:07.536 Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-06-02 21:39:07.536 Program path: C:\SierraChart\ | 2020-06-02 21:39:07.536 Data Files path: C:\SierraChart\Data\ | 2020-06-02 21:39:07.536 OS Version Number: 10.0 | 2020-06-02 21:39:07.536 Locale Setting: C | 2020-06-02 21:39:07.536 Allowed protected custom studies: | 2020-06-02 21:39:07.536 File >> Disconnect selected. | 2020-06-02 21:42:28.870 DTC Client socket (1) | CloseSocket call. | 2020-06-02 21:42:28.929 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 21:42:28.929 DTC Client socket (2) | CloseSocket call. | 2020-06-02 21:42:28.959 DTC Client socket (2) | 96 bytes remaining in receive buffer when socket closed. | 2020-06-02 21:42:28.959 SC DTC Data with Market Depth | Disconnected from the server. | 2020-06-02 21:42:28.959 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-06-02 21:42:28.959 DTC Client socket (7) | CloseSocket call. | 2020-06-02 21:42:28.959 SC DTC Delayed Exchange Data | Disconnected from the server. | 2020-06-02 21:42:28.959 DTC Client socket (7) | Shutdown started. Waiting for graceful close. | 2020-06-02 21:42:28.959 SC Futures Order Routing/Data | Disconnected. | 2020-06-02 21:42:28.959 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 21:42:29.022 DTC Client socket (1) | Closed. | 2020-06-02 21:42:29.022 DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-06-02 21:42:29.067 DTC Client socket (2) | Closed. | 2020-06-02 21:42:29.067 DTC Client socket (7) | Socket gracefully closed by remote side. | 2020-06-02 21:42:29.207 DTC Client socket (7) | Closed. | 2020-06-02 21:42:29.207 SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2020-06-02 21:44:53.294 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2020-06-02 21:44:53.303 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-06-02 21:44:53.303 SC Futures Order Routing/Data | Connected to server. | 2020-06-02 21:44:53.396 SC Futures Order Routing/Data | Starting socket receive thread. | 2020-06-02 21:44:53.396 SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS | 2020-06-02 21:44:53.396 SC Futures Order Routing/Data | Setting DTC encoding to Binary VLS | 2020-06-02 21:44:53.676 SC Futures Order Routing/Data | Sending logon request message. | 2020-06-02 21:44:53.676 SC Futures Order Routing/Data | Received logon response. | 2020-06-02 21:44:53.770 SC Futures Order Routing/Data | Server Name: SC DTC Server. | 2020-06-02 21:44:53.770 SC Futures Order Routing/Data | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 21:44:53.770 SC Futures Order Routing/Data | Successfully connected. Connected to SC DTC Protocol server. Service=trading_technologies.trading|SymbolSettings=trading_technologies_v2.trading. | 2020-06-02 21:44:53.770 SC Futures Order Routing/Data | Trading is supported. | 2020-06-02 21:44:53.770 SC Futures Order Routing/Data | Order cancel and replace is supported. | 2020-06-02 21:44:53.770 SC Futures Order Routing/Data | OCO Orders supported. | 2020-06-02 21:44:53.770 SC Futures Order Routing/Data | Bracket Orders supported. | 2020-06-02 21:44:53.770 SC Futures Order Routing/Data | Connected to data and trading server. | 2020-06-02 21:44:53.770 Triggering next historical data download in queue. | 2020-06-02 21:44:53.771 Triggering next historical data download in queue. | 2020-06-02 21:44:53.771 Triggering next historical data download in queue. | 2020-06-02 21:44:53.771 Triggering next historical data download in queue. | 2020-06-02 21:44:53.771 Updated verified funded futures trading account ending date to: 2020-07-02 19:44:54 | 2020-06-02 21:44:53.771 Mapping 6JM20_FUT_CME to 6JM20. Service code: cme | 2020-06-02 21:44:53.832 SC DTC Delayed Exchange Data | Starting real-time market data updates for: 6JM20_FUT_CME (6JM20). ID: 1 Service code: cme | 2020-06-02 21:44:53.832 SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2020-06-02 21:44:53.832 SC DTC Delayed Exchange Data | Requesting security definition data for: 6JM20_FUT_CME (6JM20). ID: 1 | 2020-06-02 21:44:53.832 Added historical Intraday data request for 6JM20_FUT_CME to the queue. | 2020-06-02 21:44:53.832 Intraday data recording state for symbol 6JM20_FUT_CME is set to download 'Pending'. | 2020-06-02 21:44:53.832 Triggering next historical data download in queue. | 2020-06-02 21:44:53.832 DTC Client socket (2) | Creating socket. | 2020-06-02 21:44:53.832 DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2020-06-02 21:44:53.832 Delaying start of download for 6JM20_FUT_CME | 2020-06-02 21:44:53.835 Mapping ESM20_FUT_CME to ESM20. Service code: cme | 2020-06-02 21:44:53.835 SC DTC Delayed Exchange Data | Starting real-time market data updates for: ESM20_FUT_CME (ESM20). ID: 2 Service code: cme | 2020-06-02 21:44:53.835 SC DTC Delayed Exchange Data | Requesting security definition data for: ESM20_FUT_CME (ESM20). ID: 2 | 2020-06-02 21:44:53.835 Requesting market depth updates for: ESM20_FUT_CME if supported. | 2020-06-02 21:44:53.835 Separate subscription for market depth updates not supported. ESM20_FUT_CME | 2020-06-02 21:44:53.835 Added historical Intraday data request for ESM20_FUT_CME to the queue. | 2020-06-02 21:44:53.835 Intraday data recording state for symbol ESM20_FUT_CME is set to download 'Pending'. | 2020-06-02 21:44:53.835 Triggering next historical data download in queue. | 2020-06-02 21:44:53.835 Mapping NQM20_FUT_CME to NQM20. Service code: cme | 2020-06-02 21:44:53.895 SC DTC Delayed Exchange Data | Starting real-time market data updates for: NQM20_FUT_CME (NQM20). ID: 3 Service code: cme | 2020-06-02 21:44:53.895 SC DTC Delayed Exchange Data | Requesting security definition data for: NQM20_FUT_CME (NQM20). ID: 3 | 2020-06-02 21:44:53.895 Added historical Intraday data request for NQM20_FUT_CME to the queue. | 2020-06-02 21:44:53.895 Intraday data recording state for symbol NQM20_FUT_CME is set to download 'Pending'. | 2020-06-02 21:44:53.895 Triggering next historical data download in queue. | 2020-06-02 21:44:53.895 Mapping MESM20_FUT_CME to MESM20. Service code: cme | 2020-06-02 21:44:53.900 SC DTC Delayed Exchange Data | Starting real-time market data updates for: MESM20_FUT_CME (MESM20). ID: 4 Service code: cme | 2020-06-02 21:44:53.900 SC DTC Delayed Exchange Data | Requesting security definition data for: MESM20_FUT_CME (MESM20). ID: 4 | 2020-06-02 21:44:53.900 Mapping RTYM20_FUT_CME to RTYM20. Service code: cme | 2020-06-02 21:44:53.912 SC DTC Delayed Exchange Data | Starting real-time market data updates for: RTYM20_FUT_CME (RTYM20). ID: 5 Service code: cme | 2020-06-02 21:44:53.912 SC DTC Delayed Exchange Data | Requesting security definition data for: RTYM20_FUT_CME (RTYM20). ID: 5 | 2020-06-02 21:44:53.912 Added historical Intraday data request for RTYM20_FUT_CME to the queue. | 2020-06-02 21:44:53.912 Intraday data recording state for symbol RTYM20_FUT_CME is set to download 'Pending'. | 2020-06-02 21:44:53.912 Triggering next historical data download in queue. | 2020-06-02 21:44:53.912 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSE. ID: 6 Service code: statscalc | 2020-06-02 21:44:53.914 SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2020-06-02 21:44:53.914 SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSE. ID: 6 | 2020-06-02 21:44:53.914 Added historical Intraday data request for TICK-NYSE to the queue. | 2020-06-02 21:44:53.914 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2020-06-02 21:44:53.914 Triggering next historical data download in queue. | 2020-06-02 21:44:53.914 DTC Client socket (3) | Creating socket. | 2020-06-02 21:44:53.914 DTC Client socket (3) | Connecting to IP: 204.15.197.14. | 2020-06-02 21:44:53.914 Mapping CLM20_FUT_NYMEX to CLM20. Service code: nymex | 2020-06-02 21:44:53.934 SC DTC Delayed Exchange Data | Starting real-time market data updates for: CLM20_FUT_NYMEX (CLM20). ID: 7 Service code: nymex | 2020-06-02 21:44:53.934 SC DTC Delayed Exchange Data | Requesting security definition data for: CLM20_FUT_NYMEX (CLM20). ID: 7 | 2020-06-02 21:44:53.934 Added historical Intraday data request for CLM20_FUT_NYMEX to the queue. | 2020-06-02 21:44:53.934 Intraday data recording state for symbol CLM20_FUT_NYMEX is set to download 'Pending'. | 2020-06-02 21:44:53.934 Triggering next historical data download in queue. | 2020-06-02 21:44:53.934 SC DTC Data with Market Depth | Starting real-time market data updates for: ADV-SP. ID: 8 Service code: statscalc | 2020-06-02 21:44:53.939 SC DTC Data with Market Depth | Requesting security definition data for: ADV-SP. ID: 8 | 2020-06-02 21:44:53.939 Added historical Intraday data request for ADV-SP to the queue. | 2020-06-02 21:44:53.939 Intraday data recording state for symbol ADV-SP is set to download 'Pending'. | 2020-06-02 21:44:53.939 Triggering next historical data download in queue. | 2020-06-02 21:44:53.939 SC DTC Delayed Exchange Data | Connected to server. | 2020-06-02 21:44:53.943 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2020-06-02 21:44:53.943 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS | 2020-06-02 21:44:53.943 Mapping GCQ20_FUT_COMEX to GCQ20. Service code: comex | 2020-06-02 21:44:53.964 SC DTC Delayed Exchange Data | Starting real-time market data updates for: GCQ20_FUT_COMEX (GCQ20). ID: 9 Service code: comex | 2020-06-02 21:44:53.964 SC DTC Delayed Exchange Data | Requesting security definition data for: GCQ20_FUT_COMEX (GCQ20). ID: 9 | 2020-06-02 21:44:53.964 Requesting market depth updates for: GCQ20_FUT_COMEX if supported. | 2020-06-02 21:44:53.964 Separate subscription for market depth updates not supported. GCQ20_FUT_COMEX | 2020-06-02 21:44:53.964 Added historical Intraday data request for GCQ20_FUT_COMEX to the queue. | 2020-06-02 21:44:53.964 Intraday data recording state for symbol GCQ20_FUT_COMEX is set to download 'Pending'. | 2020-06-02 21:44:53.964 Triggering next historical data download in queue. | 2020-06-02 21:44:53.964 SC DTC Data with Market Depth | Connected to server. | 2020-06-02 21:44:54.032 SC DTC Data with Market Depth | Starting socket receive thread. | 2020-06-02 21:44:54.032 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2020-06-02 21:44:54.032 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2020-06-02 21:44:54.102 SC DTC Delayed Exchange Data | Sending logon request message. | 2020-06-02 21:44:54.102 Mapping YMM20_FUT_CBOT to YMM20. Service code: cbot | 2020-06-02 21:44:54.112 SC DTC Delayed Exchange Data | Starting real-time market data updates for: YMM20_FUT_CBOT (YMM20). ID: 10 Service code: cbot | 2020-06-02 21:44:54.112 SC DTC Delayed Exchange Data | Requesting security definition data for: YMM20_FUT_CBOT (YMM20). ID: 10 | 2020-06-02 21:44:54.112 Added historical Intraday data request for YMM20_FUT_CBOT to the queue. | 2020-06-02 21:44:54.112 Intraday data recording state for symbol YMM20_FUT_CBOT is set to download 'Pending'. | 2020-06-02 21:44:54.112 Triggering next historical data download in queue. | 2020-06-02 21:44:54.112 Mapping GCM20_FUT_COMEX to GCM20. Service code: comex | 2020-06-02 21:44:54.113 SC DTC Delayed Exchange Data | Starting real-time market data updates for: GCM20_FUT_COMEX (GCM20). ID: 11 Service code: comex | 2020-06-02 21:44:54.113 SC DTC Delayed Exchange Data | Requesting security definition data for: GCM20_FUT_COMEX (GCM20). ID: 11 | 2020-06-02 21:44:54.113 Added historical Intraday data request for GCM20_FUT_COMEX to the queue. | 2020-06-02 21:44:54.113 Intraday data recording state for symbol GCM20_FUT_COMEX is set to download 'Pending'. | 2020-06-02 21:44:54.113 Triggering next historical data download in queue. | 2020-06-02 21:44:54.113 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2020-06-02 21:44:54.169 SC DTC Data with Market Depth | Sending logon request message. | 2020-06-02 21:44:54.169 Mapping ZBM20_FUT_CBOT to ZBM20. Service code: cbot | 2020-06-02 21:44:54.230 SC DTC Delayed Exchange Data | Starting real-time market data updates for: ZBM20_FUT_CBOT (ZBM20). ID: 12 Service code: cbot | 2020-06-02 21:44:54.230 SC DTC Delayed Exchange Data | Requesting security definition data for: ZBM20_FUT_CBOT (ZBM20). ID: 12 | 2020-06-02 21:44:54.230 Added historical Intraday data request for ZBM20_FUT_CBOT to the queue. | 2020-06-02 21:44:54.230 Intraday data recording state for symbol ZBM20_FUT_CBOT is set to download 'Pending'. | 2020-06-02 21:44:54.230 Triggering next historical data download in queue. | 2020-06-02 21:44:54.230 Mapping ESU20_FUT_CME to ESU20. Service code: cme | 2020-06-02 21:44:54.257 SC DTC Delayed Exchange Data | Starting real-time market data updates for: ESU20_FUT_CME (ESU20). ID: 13 Service code: cme | 2020-06-02 21:44:54.257 SC DTC Delayed Exchange Data | Requesting security definition data for: ESU20_FUT_CME (ESU20). ID: 13 | 2020-06-02 21:44:54.257 Mapping ESZ20_FUT_CME to ESZ20. Service code: cme | 2020-06-02 21:44:54.257 SC DTC Delayed Exchange Data | Starting real-time market data updates for: ESZ20_FUT_CME (ESZ20). ID: 14 Service code: cme | 2020-06-02 21:44:54.257 SC DTC Delayed Exchange Data | Requesting security definition data for: ESZ20_FUT_CME (ESZ20). ID: 14 | 2020-06-02 21:44:54.257 Mapping ZBU20_FUT_CBOT to ZBU20. Service code: cbot | 2020-06-02 21:44:54.257 SC DTC Delayed Exchange Data | Starting real-time market data updates for: ZBU20_FUT_CBOT (ZBU20). ID: 15 Service code: cbot | 2020-06-02 21:44:54.257 SC DTC Delayed Exchange Data | Requesting security definition data for: ZBU20_FUT_CBOT (ZBU20). ID: 15 | 2020-06-02 21:44:54.257 Mapping ZBZ20_FUT_CBOT to ZBZ20. Service code: cbot | 2020-06-02 21:44:54.257 SC DTC Delayed Exchange Data | Starting real-time market data updates for: ZBZ20_FUT_CBOT (ZBZ20). ID: 16 Service code: cbot | 2020-06-02 21:44:54.257 SC DTC Delayed Exchange Data | Requesting security definition data for: ZBZ20_FUT_CBOT (ZBZ20). ID: 16 | 2020-06-02 21:44:54.257 Mapping 6JU20_FUT_CME to 6JU20. Service code: cme | 2020-06-02 21:44:54.257 SC DTC Delayed Exchange Data | Starting real-time market data updates for: 6JU20_FUT_CME (6JU20). ID: 17 Service code: cme | 2020-06-02 21:44:54.257 SC DTC Delayed Exchange Data | Requesting security definition data for: 6JU20_FUT_CME (6JU20). ID: 17 | 2020-06-02 21:44:54.257 Mapping 6JZ20_FUT_CME to 6JZ20. Service code: cme | 2020-06-02 21:44:54.257 SC DTC Delayed Exchange Data | Starting real-time market data updates for: 6JZ20_FUT_CME (6JZ20). ID: 18 Service code: cme | 2020-06-02 21:44:54.258 SC DTC Delayed Exchange Data | Requesting security definition data for: 6JZ20_FUT_CME (6JZ20). ID: 18 | 2020-06-02 21:44:54.258 Mapping GCZ20_FUT_COMEX to GCZ20. Service code: comex | 2020-06-02 21:44:54.258 SC DTC Delayed Exchange Data | Starting real-time market data updates for: GCZ20_FUT_COMEX (GCZ20). ID: 19 Service code: comex | 2020-06-02 21:44:54.258 SC DTC Delayed Exchange Data | Requesting security definition data for: GCZ20_FUT_COMEX (GCZ20). ID: 19 | 2020-06-02 21:44:54.258 Mapping CLK20_FUT_NYMEX to CLK20. Service code: nymex | 2020-06-02 21:44:54.258 SC DTC Delayed Exchange Data | Starting real-time market data updates for: CLK20_FUT_NYMEX (CLK20). ID: 20 Service code: nymex | 2020-06-02 21:44:54.258 SC DTC Delayed Exchange Data | Requesting security definition data for: CLK20_FUT_NYMEX (CLK20). ID: 20 | 2020-06-02 21:44:54.258 Mapping CLN20_FUT_NYMEX to CLN20. Service code: nymex | 2020-06-02 21:44:54.258 SC DTC Delayed Exchange Data | Starting real-time market data updates for: CLN20_FUT_NYMEX (CLN20). ID: 21 Service code: nymex | 2020-06-02 21:44:54.258 SC DTC Delayed Exchange Data | Requesting security definition data for: CLN20_FUT_NYMEX (CLN20). ID: 21 | 2020-06-02 21:44:54.258 SC DTC Delayed Exchange Data | Received logon response. | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Successfully connected. | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Trading is not supported. | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: 6JM20_FUT_CME -> 6JM20 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: 6JU20_FUT_CME -> 6JU20 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: 6JZ20_FUT_CME -> 6JZ20 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: CLK20_FUT_NYMEX -> CLK20 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: CLM20_FUT_NYMEX -> CLM20 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: CLN20_FUT_NYMEX -> CLN20 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: ESM20_FUT_CME -> ESM20. Market Depth data restarted. | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: ESU20_FUT_CME -> ESU20 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: ESZ20_FUT_CME -> ESZ20 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: GCM20_FUT_COMEX -> GCM20 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: GCQ20_FUT_COMEX -> GCQ20. Market Depth data restarted. | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: GCZ20_FUT_COMEX -> GCZ20 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MESM20_FUT_CME -> MESM20 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQM20_FUT_CME -> NQM20 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: RTYM20_FUT_CME -> RTYM20 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: YMM20_FUT_CBOT -> YMM20 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: ZBM20_FUT_CBOT -> ZBM20 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: ZBU20_FUT_CBOT -> ZBU20 | 2020-06-02 21:44:54.661 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: ZBZ20_FUT_CBOT -> ZBZ20 | 2020-06-02 21:44:54.661 SC DTC Data with Market Depth | Received logon response. | 2020-06-02 21:44:54.784 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2020-06-02 21:44:54.784 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 21:44:54.784 SC DTC Data with Market Depth | Successfully connected. | 2020-06-02 21:44:54.784 SC DTC Data with Market Depth | Trading is not supported. | 2020-06-02 21:44:54.784 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADV-SP | 2020-06-02 21:44:54.784 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSE | 2020-06-02 21:44:54.784 SC DTC Data with Market Depth | Received security definition for symbol ADV-SP | 2020-06-02 21:44:54.913 SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE | 2020-06-02 21:44:54.913 SC DTC Delayed Exchange Data | Clearing market depth for ESM20_FUT_CME | 2020-06-02 21:44:55.003 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESM20_FUT_CME.2020-06-02.depth | 2020-06-02 21:44:55.003 SC DTC Delayed Exchange Data | Clearing market depth for GCQ20_FUT_COMEX | 2020-06-02 21:44:55.003 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\GCQ20_FUT_COMEX.2020-06-02.depth | 2020-06-02 21:44:55.003 SC DTC Delayed Exchange Data | Received security definition for symbol 6JM20_FUT_CME | 2020-06-02 21:44:55.003 SC DTC Delayed Exchange Data | Received security definition for symbol 6JU20_FUT_CME | 2020-06-02 21:44:55.003 SC DTC Delayed Exchange Data | Received security definition for symbol 6JZ20_FUT_CME | 2020-06-02 21:44:55.003 SC DTC Delayed Exchange Data | Real-time data for symbol CLK20_FUT_NYMEX is currently unavailable. | 2020-06-02 21:44:55.003 SC DTC Delayed Exchange Data | Received security definition for symbol CLK20_FUT_NYMEX | 2020-06-02 21:44:55.003 SC DTC Delayed Exchange Data | Real-time data for symbol CLM20_FUT_NYMEX is currently unavailable. | 2020-06-02 21:44:55.003 SC DTC Delayed Exchange Data | Received security definition for symbol CLM20_FUT_NYMEX | 2020-06-02 21:44:55.003 SC DTC Delayed Exchange Data | Received security definition for symbol CLN20_FUT_NYMEX | 2020-06-02 21:44:55.003 SC DTC Delayed Exchange Data | Received security definition for symbol ESM20_FUT_CME | 2020-06-02 21:44:55.003 SC DTC Delayed Exchange Data | Received security definition for symbol ESU20_FUT_CME | 2020-06-02 21:44:55.003 SC DTC Delayed Exchange Data | Received security definition for symbol ESZ20_FUT_CME | 2020-06-02 21:44:55.003 SC DTC Delayed Exchange Data | Received security definition for symbol GCM20_FUT_COMEX | 2020-06-02 21:44:55.003 SC DTC Delayed Exchange Data | Received security definition for symbol GCQ20_FUT_COMEX | 2020-06-02 21:44:55.003 SC DTC Delayed Exchange Data | Received security definition for symbol GCZ20_FUT_COMEX | 2020-06-02 21:44:55.005 SC DTC Delayed Exchange Data | Received security definition for symbol MESM20_FUT_CME | 2020-06-02 21:44:55.005 SC DTC Delayed Exchange Data | Received security definition for symbol NQM20_FUT_CME | 2020-06-02 21:44:55.005 SC DTC Delayed Exchange Data | Received security definition for symbol RTYM20_FUT_CME | 2020-06-02 21:44:55.005 SC DTC Delayed Exchange Data | Received security definition for symbol YMM20_FUT_CBOT | 2020-06-02 21:44:55.005 SC DTC Delayed Exchange Data | Received security definition for symbol ZBM20_FUT_CBOT | 2020-06-02 21:44:55.005 SC DTC Delayed Exchange Data | Received security definition for symbol ZBU20_FUT_CBOT | 2020-06-02 21:44:55.005 SC DTC Delayed Exchange Data | Received security definition for symbol ZBZ20_FUT_CBOT | 2020-06-02 21:44:55.005 HD Request # 24 | Downloading Intraday chart data for 6JM20_FUT_CME to the file 6JM20_FUT_CME.scid. Service: cme | 2020-06-02 21:45:00.816 HD Request # 24 | Download start date-time: 2020-06-02 21:32:14.000 | 2020-06-02 21:45:00.816 HD Request # 24 | Using server: ds21.sierracharts.com port 10150 | 2020-06-02 21:45:00.816 Socket (4) | Creating socket. | 2020-06-02 21:45:00.817 Socket (4) | Connecting to IP: 216.1.90.129. | 2020-06-02 21:45:00.817 HD Request # 24 | Setting DTC encoding to Binary VLS | 2020-06-02 21:45:01.037 HD Request # 24 | Sending historical data logon request message. | 2020-06-02 21:45:01.037 HD Request # 24 | Requesting Intraday data. Start date-time: 2020-06-02 21:32:14. Record interval: 0. Symbol: 6JM20 | 2020-06-02 21:45:01.590 HD Request # 24 | Decompressing data. | 2020-06-02 21:45:01.697 HD Request # 24 | Receiving Intraday data for 6JM20_FUT_CME starting at 2020-06-02 21:32:14 | 2020-06-02 21:45:01.698 Socket (4) | CloseSocket call. | 2020-06-02 21:45:01.698 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-06-02 21:45:01.698 Historical data download thread signaled to stop. | 2020-06-02 21:45:01.700 HD Request # 24 | Timestamp of first Intraday data file record written: 2020-06-02 21:32:49 | 2020-06-02 21:45:01.700 HD Request # 24 | Received 368 records from 2020-06-02 21:32:14.000 to 2020-06-02 21:44:50.006 (12.6 minutes) and wrote 367 records for 6JM20_FUT_CME | 2020-06-02 21:45:01.700 HD Request # 24 | Completion time: 1s | 2020-06-02 21:45:01.703 HD Request # 24 | Intraday data download complete for 6JM20_FUT_CME. Unique request ID: 23 | 2020-06-02 21:45:01.703 Removing historical data download ID 23. | 2020-06-02 21:45:01.703 Real-time Intraday chart data file updates started for 6JM20_FUT_CME | 2020-06-02 21:45:01.703 Intraday chart data file opened for 6JM20_FUT_CME | 2020-06-02 21:45:01.703 HD Request # 24 | Enabling Intraday chart updating for symbol. | 2020-06-02 21:45:01.703 Triggering next historical data download in queue. | 2020-06-02 21:45:01.703 HD Request # 25 | Downloading Intraday chart data for ESM20_FUT_CME to the file ESM20_FUT_CME.scid. Service: cme | 2020-06-02 21:45:01.703 HD Request # 25 | Download start date-time: 2020-06-02 21:32:18.000 | 2020-06-02 21:45:01.704 HD Request # 25 | Using server: ds23.sierracharts.com port 10149 | 2020-06-02 21:45:01.704 Socket (5) | Creating socket. | 2020-06-02 21:45:01.704 Socket (5) | Connecting to IP: 216.1.90.130. | 2020-06-02 21:45:01.704 Chart #6 has tagged chart #4 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 21:45:01.776 Socket (4) | Socket gracefully closed by remote side. | 2020-06-02 21:45:01.806 Socket (4) | Closed. | 2020-06-02 21:45:01.806 HD Request # 25 | Setting DTC encoding to Binary VLS | 2020-06-02 21:45:01.919 HD Request # 25 | Sending historical data logon request message. | 2020-06-02 21:45:01.919 ESM20_FUT_CME [CBV][M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: CHT Last.Cht | 2020-06-02 21:45:02.107 HD Request # 25 | Requesting Intraday data. Start date-time: 2020-06-02 21:32:18. Record interval: 0. Symbol: ESM20 | 2020-06-02 21:45:02.472 HD Request # 25 | Decompressing data. | 2020-06-02 21:45:02.580 HD Request # 25 | Receiving Intraday data for ESM20_FUT_CME starting at 2020-06-02 21:32:18 | 2020-06-02 21:45:02.904 Socket (5) | CloseSocket call. | 2020-06-02 21:45:02.906 Historical data download thread signaled to stop. | 2020-06-02 21:45:02.906 Socket (5) | Shutdown started. Waiting for graceful close. | 2020-06-02 21:45:02.906 HD Request # 25 | Timestamp of first Intraday data file record written: 2020-06-02 21:32:20 | 2020-06-02 21:45:02.906 HD Request # 25 | Received 14675 records from 2020-06-02 21:32:18.000 to 2020-06-02 21:45:00.026 (12.7 minutes) and wrote 14648 records for ESM20_FUT_CME | 2020-06-02 21:45:02.906 HD Request # 25 | Completion time: 0s | 2020-06-02 21:45:02.909 HD Request # 25 | Intraday data download complete for ESM20_FUT_CME. Unique request ID: 24 | 2020-06-02 21:45:02.909 Removing historical data download ID 24. | 2020-06-02 21:45:02.909 Real-time Intraday chart data file updates started for ESM20_FUT_CME | 2020-06-02 21:45:02.909 Intraday chart data file opened for ESM20_FUT_CME | 2020-06-02 21:45:02.909 HD Request # 25 | Enabling Intraday chart updating for symbol. | 2020-06-02 21:45:02.909 Triggering next historical data download in queue. | 2020-06-02 21:45:02.909 HD Request # 26 | Downloading Intraday chart data for NQM20_FUT_CME to the file NQM20_FUT_CME.scid. Service: cme | 2020-06-02 21:45:02.909 HD Request # 26 | Download start date-time: 2020-06-02 21:32:18.000 | 2020-06-02 21:45:02.910 HD Request # 26 | Using server: ds21.sierracharts.com port 10150 | 2020-06-02 21:45:02.910 Socket (4) | Creating socket. | 2020-06-02 21:45:02.910 Socket (4) | Connecting to IP: 216.1.90.129. | 2020-06-02 21:45:02.910 Chart #3 has tagged chart #4 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 21:45:02.969 Chart #3 has tagged chart #8 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 21:45:02.969 ESM20_FUT_CME [CV][M] Rev. 4t #4 | Performing a full recalculation because it has been tagged. Chartbook: SP500.Cht | 2020-06-02 21:45:02.995 Chart #23 has tagged chart #4 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 21:45:03.004 Chart #23 has tagged chart #8 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 21:45:03.004 Chart #23 has tagged chart #14 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 21:45:03.006 Socket (5) | Socket gracefully closed by remote side. | 2020-06-02 21:45:03.008 Socket (5) | Closed. | 2020-06-02 21:45:03.008 Opened cached Intraday file: C:\SierraChart\Data\ESM20_FUT_CME.scid. Thread ID: 10400 | 2020-06-02 21:45:03.070 ESM20_FUT_CME [CV][M] Rev. 4t #8 | Performing a full recalculation because it has been tagged. Chartbook: SP500.Cht | 2020-06-02 21:45:03.082 Chart #20 has tagged chart #8 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 21:45:03.101 HD Request # 26 | Setting DTC encoding to Binary VLS | 2020-06-02 21:45:03.123 HD Request # 26 | Sending historical data logon request message. | 2020-06-02 21:45:03.123 Chart #3 has tagged chart #14 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 21:45:03.152 Chart #10 has tagged chart #14 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 21:45:03.156 Chart #10 has tagged chart #4 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 21:45:03.181 Chart #10 has tagged chart #8 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 21:45:03.181 Chart #25 has tagged chart #14 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 21:45:03.205 HD Request # 26 | Requesting Intraday data. Start date-time: 2020-06-02 21:32:18. Record interval: 0. Symbol: NQM20 | 2020-06-02 21:45:03.227 ESM20_FUT_CME [CV][M] Rev. 4t #14 | Performing a full recalculation because it has been tagged. Chartbook: CHT Last.Cht | 2020-06-02 21:45:03.283 HD Request # 26 | Decompressing data. | 2020-06-02 21:45:03.331 Chart #24 has tagged chart #14 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 21:45:03.353 Chart #24 has tagged chart #5 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 21:45:03.353 Chart #25 has tagged chart #4 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 21:45:03.361 Chart #25 has tagged chart #8 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 21:45:03.361 Opened cached Intraday file: C:\SierraChart\Data\6JM20_FUT_CME.scid. Thread ID: 10400 | 2020-06-02 21:45:03.403 Chart #20 has tagged chart #14 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 21:45:03.410 ESM20_FUT_CME [CV][M] Rev. 4t #4 | Performing a full recalculation because it has been tagged. Chartbook: SP500.Cht | 2020-06-02 21:45:03.434 ESM20_FUT_CME [CV][M] Rev. 4t #8 | Performing a full recalculation because it has been tagged. Chartbook: SP500.Cht | 2020-06-02 21:45:03.533 HD Request # 26 | Receiving Intraday data for NQM20_FUT_CME starting at 2020-06-02 21:32:18 | 2020-06-02 21:45:03.545 Socket (4) | CloseSocket call. | 2020-06-02 21:45:03.546 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-06-02 21:45:03.546 Historical data download thread signaled to stop. | 2020-06-02 21:45:03.547 HD Request # 26 | Timestamp of first Intraday data file record written: 2020-06-02 21:32:19 | 2020-06-02 21:45:03.547 HD Request # 26 | Received 6404 records from 2020-06-02 21:32:18.000 to 2020-06-02 21:45:00.018 (12.7 minutes) and wrote 6398 records for NQM20_FUT_CME | 2020-06-02 21:45:03.547 HD Request # 26 | Completion time: 0s | 2020-06-02 21:45:03.551 HD Request # 26 | Intraday data download complete for NQM20_FUT_CME. Unique request ID: 25 | 2020-06-02 21:45:03.551 Removing historical data download ID 25. | 2020-06-02 21:45:03.551 Real-time Intraday chart data file updates started for NQM20_FUT_CME | 2020-06-02 21:45:03.551 Intraday chart data file opened for NQM20_FUT_CME | 2020-06-02 21:45:03.551 HD Request # 26 | Enabling Intraday chart updating for symbol. | 2020-06-02 21:45:03.551 Triggering next historical data download in queue. | 2020-06-02 21:45:03.551 HD Request # 27 | Downloading Intraday chart data for RTYM20_FUT_CME to the file RTYM20_FUT_CME.scid. Service: cme | 2020-06-02 21:45:03.551 HD Request # 27 | Download start date-time: 2020-06-02 21:32:19.000 | 2020-06-02 21:45:03.551 HD Request # 27 | Using server: ds23.sierracharts.com port 10149 | 2020-06-02 21:45:03.551 Socket (5) | Creating socket. | 2020-06-02 21:45:03.551 Socket (5) | Connecting to IP: 216.1.90.130. | 2020-06-02 21:45:03.551 Socket (4) | Socket gracefully closed by remote side. | 2020-06-02 21:45:03.650 Socket (4) | Closed. | 2020-06-02 21:45:03.650 ESM20_FUT_CME [CBV][M] Rev. 4t #5 | Performing a full recalculation because it has been tagged. Chartbook: CHT Last.Cht | 2020-06-02 21:45:03.724 ESM20_FUT_CME [CV][M] Rev. 4t #14 | Performing a full recalculation because it has been tagged. Chartbook: CHT Last.Cht | 2020-06-02 21:45:03.773 HD Request # 27 | Setting DTC encoding to Binary VLS | 2020-06-02 21:45:03.783 HD Request # 27 | Sending historical data logon request message. | 2020-06-02 21:45:03.783 Chart #8 has tagged chart #4 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 21:45:03.819 HD Request # 27 | Requesting Intraday data. Start date-time: 2020-06-02 21:32:19. Record interval: 0. Symbol: RTYM20 | 2020-06-02 21:45:03.893 Opened cached Intraday file: C:\SierraChart\Data\NQM20_FUT_CME.scid. Thread ID: 10400 | 2020-06-02 21:45:03.928 HD Request # 27 | Decompressing data. | 2020-06-02 21:45:04.005 ESM20_FUT_CME [CBV][M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: CHT Last.Cht | 2020-06-02 21:45:04.107 HD Request # 27 | Receiving Intraday data for RTYM20_FUT_CME starting at 2020-06-02 21:32:19 | 2020-06-02 21:45:04.125 Socket (5) | CloseSocket call. | 2020-06-02 21:45:04.125 Socket (5) | Shutdown started. Waiting for graceful close. | 2020-06-02 21:45:04.125 Historical data download thread signaled to stop. | 2020-06-02 21:45:04.209 HD Request # 27 | Timestamp of first Intraday data file record written: 2020-06-02 21:32:19 | 2020-06-02 21:45:04.209 HD Request # 27 | Received 2868 records from 2020-06-02 21:32:19.000 to 2020-06-02 21:45:00.002 (12.7 minutes) and wrote 2867 records for RTYM20_FUT_CME | 2020-06-02 21:45:04.210 HD Request # 27 | Completion time: 1s | 2020-06-02 21:45:04.213 HD Request # 27 | Intraday data download complete for RTYM20_FUT_CME. Unique request ID: 26 | 2020-06-02 21:45:04.213 Removing historical data download ID 26. | 2020-06-02 21:45:04.213 Real-time Intraday chart data file updates started for RTYM20_FUT_CME | 2020-06-02 21:45:04.213 Intraday chart data file opened for RTYM20_FUT_CME | 2020-06-02 21:45:04.213 HD Request # 27 | Enabling Intraday chart updating for symbol. | 2020-06-02 21:45:04.213 Triggering next historical data download in queue. | 2020-06-02 21:45:04.213 HD Request # 28 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2020-06-02 21:45:04.213 HD Request # 28 | Download start date-time: 2020-06-02 21:42:28.000 | 2020-06-02 21:45:04.213 HD Request # 28 | Using server: ds12.sierracharts.com port 10150 | 2020-06-02 21:45:04.214 Socket (4) | Creating socket. | 2020-06-02 21:45:04.214 Socket (4) | Connecting to IP: 204.15.197.14. | 2020-06-02 21:45:04.214 Socket (5) | Socket gracefully closed by remote side. | 2020-06-02 21:45:04.236 Socket (5) | Closed. | 2020-06-02 21:45:04.236 Chart #19 has tagged chart #4 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 21:45:04.356 HD Request # 28 | Setting DTC encoding to Binary VLS | 2020-06-02 21:45:04.477 HD Request # 28 | Sending historical data logon request message. | 2020-06-02 21:45:04.477 ESM20_FUT_CME [CBV][M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: CHT Last.Cht | 2020-06-02 21:45:04.605 Opened cached Intraday file: C:\SierraChart\Data\RTYM20_FUT_CME.scid. Thread ID: 10400 | 2020-06-02 21:45:04.723 HD Request # 28 | Requesting Intraday data. Start date-time: 2020-06-02 21:42:28. Record interval: 0. Symbol: TICK-NYSE | 2020-06-02 21:45:05.084 HD Request # 28 | Decompressing data. | 2020-06-02 21:45:05.210 HD Request # 28 | Receiving Intraday data for TICK-NYSE starting at 2020-06-02 21:42:28 | 2020-06-02 21:45:05.211 Socket (4) | CloseSocket call. | 2020-06-02 21:45:05.212 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-06-02 21:45:05.212 Historical data download thread signaled to stop. | 2020-06-02 21:45:05.212 HD Request # 28 | Timestamp of first Intraday data file record written: 2020-06-02 21:42:29 | 2020-06-02 21:45:05.212 HD Request # 28 | Received 158 records from 2020-06-02 21:42:28.000 to 2020-06-02 21:45:05.000 (2.6 minutes) and wrote 157 records for TICK-NYSE | 2020-06-02 21:45:05.213 Added 5 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2020-06-02 21:45:05.216 HD Request # 28 | Completion time: 1s | 2020-06-02 21:45:05.218 HD Request # 28 | Intraday data download complete for TICK-NYSE. Unique request ID: 27 | 2020-06-02 21:45:05.218 Removing historical data download ID 27. | 2020-06-02 21:45:05.218 Real-time Intraday chart data file updates started for TICK-NYSE | 2020-06-02 21:45:05.218 Intraday chart data file opened for TICK-NYSE | 2020-06-02 21:45:05.218 HD Request # 28 | Enabling Intraday chart updating for symbol. | 2020-06-02 21:45:05.218 Triggering next historical data download in queue. | 2020-06-02 21:45:05.218 HD Request # 29 | Downloading Intraday chart data for CLM20_FUT_NYMEX to the file CLM20_FUT_NYMEX.scid. Service: nymex | 2020-06-02 21:45:05.218 HD Request # 29 | Download start date-time: 2020-05-19 20:29:55.000 | 2020-06-02 21:45:05.219 HD Request # 29 | Using server: ds21.sierracharts.com port 10149 | 2020-06-02 21:45:05.219 Socket (5) | Creating socket. | 2020-06-02 21:45:05.219 Socket (5) | Connecting to IP: 216.1.90.129. | 2020-06-02 21:45:05.219 Socket (4) | Socket gracefully closed by remote side. | 2020-06-02 21:45:05.338 Socket (4) | Closed. | 2020-06-02 21:45:05.338 HD Request # 29 | Setting DTC encoding to Binary VLS | 2020-06-02 21:45:05.443 HD Request # 29 | Sending historical data logon request message. | 2020-06-02 21:45:05.443 Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid. Thread ID: 3024 | 2020-06-02 21:45:05.456 Chart #24 has tagged chart #17 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 21:45:05.542 Chart #24 has tagged chart #21 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 21:45:05.542 Chart #24 has tagged chart #4 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 21:45:05.542 Chart #24 has tagged chart #8 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 21:45:05.542 ESM20_FUT_CME [CBV][M] Rev. 4t #21 | Performing a full recalculation because it has been tagged. Chartbook: SP500.Cht | 2020-06-02 21:45:05.930 ESM20_FUT_CME [CV][M] Rev. 4t #4 | Performing a full recalculation because it has been tagged. Chartbook: SP500.Cht | 2020-06-02 21:45:05.943 HD Request # 29 | Requesting Intraday data. Start date-time: 2020-05-19 20:29:55. Record interval: 0. Symbol: CLM20 | 2020-06-02 21:45:05.989 ESM20_FUT_CME [CV][M] Rev. 4t #8 | Performing a full recalculation because it has been tagged. Chartbook: SP500.Cht | 2020-06-02 21:45:06.033 ESM20_FUT_CME [CBV][M] Rev. 4t #17 | Performing a full recalculation because it has been tagged. Chartbook: SP500.Cht | 2020-06-02 21:45:06.039 HD Request # 29 | Decompressing data. | 2020-06-02 21:45:06.099 HD Request # 29 | Receiving Intraday data for CLM20_FUT_NYMEX starting at 2020-05-19 20:29:55 | 2020-06-02 21:45:06.099 Socket (5) | CloseSocket call. | 2020-06-02 21:45:06.099 Socket (5) | Shutdown started. Waiting for graceful close. | 2020-06-02 21:45:06.099 Historical data download thread signaled to stop. | 2020-06-02 21:45:06.102 HD Request # 29 | Received 1 record from 2020-05-19 20:29:55.000 to 2020-05-19 20:29:55.000 (0.0 seconds) and wrote 0 records for CLM20_FUT_NYMEX | 2020-06-02 21:45:06.102 HD Request # 29 | Completion time: 0s | 2020-06-02 21:45:06.102 HD Request # 29 | Intraday data download complete for CLM20_FUT_NYMEX. Unique request ID: 28 | 2020-06-02 21:45:06.102 Removing historical data download ID 28. | 2020-06-02 21:45:06.102 Real-time Intraday chart data file updates started for CLM20_FUT_NYMEX | 2020-06-02 21:45:06.102 Intraday chart data file opened for CLM20_FUT_NYMEX | 2020-06-02 21:45:06.102 HD Request # 29 | Enabling Intraday chart updating for symbol. | 2020-06-02 21:45:06.102 Triggering next historical data download in queue. | 2020-06-02 21:45:06.102 HD Request # 30 | Downloading Intraday chart data for ADV-SP to the file ADV-SP.scid. Service: statscalc | 2020-06-02 21:45:06.102 HD Request # 30 | Download start date-time: 2020-06-02 21:42:28.000 | 2020-06-02 21:45:06.102 HD Request # 30 | Using server: ds3.sierracharts.com port 10150 | 2020-06-02 21:45:06.103 Socket (4) | Creating socket. | 2020-06-02 21:45:06.103 Socket (4) | Connecting to IP: 65.182.172.42. | 2020-06-02 21:45:06.103 Socket (5) | Socket gracefully closed by remote side. | 2020-06-02 21:45:06.209 Socket (5) | Closed. | 2020-06-02 21:45:06.210 HD Request # 30 | Setting DTC encoding to Binary VLS | 2020-06-02 21:45:06.303 HD Request # 30 | Sending historical data logon request message. | 2020-06-02 21:45:06.303 HD Request # 30 | Requesting Intraday data. Start date-time: 2020-06-02 21:42:28. Record interval: 0. Symbol: ADV-SP | 2020-06-02 21:45:06.395 Chart #11 has tagged chart #4 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 21:45:06.397 HD Request # 30 | Decompressing data. | 2020-06-02 21:45:06.489 HD Request # 30 | Receiving Intraday data for ADV-SP starting at 2020-06-02 21:42:28 | 2020-06-02 21:45:06.490 Socket (4) | CloseSocket call. | 2020-06-02 21:45:06.491 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-06-02 21:45:06.491 Historical data download thread signaled to stop. | 2020-06-02 21:45:06.491 HD Request # 30 | Timestamp of first Intraday data file record written: 2020-06-02 21:42:29 | 2020-06-02 21:45:06.491 HD Request # 30 | Received 157 records from 2020-06-02 21:42:28.000 to 2020-06-02 21:45:04.000 (2.6 minutes) and wrote 156 records for ADV-SP | 2020-06-02 21:45:06.491 Added 11 Time and Sales records to Intraday data file for ADV-SP after download. | 2020-06-02 21:45:06.495 HD Request # 30 | Completion time: 0s | 2020-06-02 21:45:06.497 HD Request # 30 | Intraday data download complete for ADV-SP. Unique request ID: 29 | 2020-06-02 21:45:06.497 Removing historical data download ID 29. | 2020-06-02 21:45:06.497 Real-time Intraday chart data file updates started for ADV-SP | 2020-06-02 21:45:06.497 Intraday chart data file opened for ADV-SP | 2020-06-02 21:45:06.497 HD Request # 30 | Enabling Intraday chart updating for symbol. | 2020-06-02 21:45:06.497 Triggering next historical data download in queue. | 2020-06-02 21:45:06.497 HD Request # 31 | Downloading Intraday chart data for GCQ20_FUT_COMEX to the file GCQ20_FUT_COMEX.scid. Service: comex | 2020-06-02 21:45:06.497 HD Request # 31 | Download start date-time: 2020-06-02 21:32:14.000 | 2020-06-02 21:45:06.497 HD Request # 31 | Using server: ds23.sierracharts.com port 10149 | 2020-06-02 21:45:06.497 Socket (5) | Creating socket. | 2020-06-02 21:45:06.497 Socket (5) | Connecting to IP: 216.1.90.130. | 2020-06-02 21:45:06.497 Socket (4) | Socket gracefully closed by remote side. | 2020-06-02 21:45:06.584 Socket (4) | Closed. | 2020-06-02 21:45:06.584 ESM20_FUT_CME [CBV][M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: CHT Last.Cht | 2020-06-02 21:45:06.606 HD Request # 31 | Setting DTC encoding to Binary VLS | 2020-06-02 21:45:06.720 HD Request # 31 | Sending historical data logon request message. | 2020-06-02 21:45:06.720 HD Request # 31 | Requesting Intraday data. Start date-time: 2020-06-02 21:32:14. Record interval: 0. Symbol: GCQ20 | 2020-06-02 21:45:06.824 HD Request # 31 | Decompressing data. | 2020-06-02 21:45:06.931 HD Request # 31 | Receiving Intraday data for GCQ20_FUT_COMEX starting at 2020-06-02 21:32:14 | 2020-06-02 21:45:06.932 Socket (5) | CloseSocket call. | 2020-06-02 21:45:06.934 Socket (5) | Shutdown started. Waiting for graceful close. | 2020-06-02 21:45:06.934 Historical data download thread signaled to stop. | 2020-06-02 21:45:06.939 HD Request # 31 | Timestamp of first Intraday data file record written: 2020-06-02 21:32:20 | 2020-06-02 21:45:06.939 HD Request # 31 | Received 252 records from 2020-06-02 21:32:14.000 to 2020-06-02 21:35:06.000 (2.9 minutes) and wrote 251 records for GCQ20_FUT_COMEX | 2020-06-02 21:45:06.939 HD Request # 31 | Completion time: 0s | 2020-06-02 21:45:06.949 HD Request # 31 | Intraday data download complete for GCQ20_FUT_COMEX. Unique request ID: 30 | 2020-06-02 21:45:06.949 Removing historical data download ID 30. | 2020-06-02 21:45:06.949 Real-time Intraday chart data file updates started for GCQ20_FUT_COMEX | 2020-06-02 21:45:06.949 Intraday chart data file opened for GCQ20_FUT_COMEX | 2020-06-02 21:45:06.949 HD Request # 31 | Enabling Intraday chart updating for symbol. | 2020-06-02 21:45:06.949 Triggering next historical data download in queue. | 2020-06-02 21:45:06.949 HD Request # 32 | Downloading Intraday chart data for YMM20_FUT_CBOT to the file YMM20_FUT_CBOT.scid. Service: cbot | 2020-06-02 21:45:06.949 HD Request # 32 | Download start date-time: 2020-06-02 21:32:18.000 | 2020-06-02 21:45:06.949 HD Request # 32 | Using server: ds21.sierracharts.com port 10150 | 2020-06-02 21:45:06.949 Socket (4) | Creating socket. | 2020-06-02 21:45:06.950 Socket (4) | Connecting to IP: 216.1.90.129. | 2020-06-02 21:45:06.950 Socket (5) | Socket gracefully closed by remote side. | 2020-06-02 21:45:07.039 Socket (5) | Closed. | 2020-06-02 21:45:07.039 HD Request # 32 | Setting DTC encoding to Binary VLS | 2020-06-02 21:45:07.169 HD Request # 32 | Sending historical data logon request message. | 2020-06-02 21:45:07.169 HD Request # 32 | Requesting Intraday data. Start date-time: 2020-06-02 21:32:18. Record interval: 0. Symbol: YMM20 | 2020-06-02 21:45:07.272 HD Request # 32 | Decompressing data. | 2020-06-02 21:45:07.376 HD Request # 32 | Receiving Intraday data for YMM20_FUT_CBOT starting at 2020-06-02 21:32:18 | 2020-06-02 21:45:07.377 Socket (4) | CloseSocket call. | 2020-06-02 21:45:07.378 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-06-02 21:45:07.378 Historical data download thread signaled to stop. | 2020-06-02 21:45:07.378 HD Request # 32 | Timestamp of first Intraday data file record written: 2020-06-02 21:32:19 | 2020-06-02 21:45:07.378 HD Request # 32 | Received 530 records from 2020-06-02 21:32:18.000 to 2020-06-02 21:35:07.000 (2.8 minutes) and wrote 527 records for YMM20_FUT_CBOT | 2020-06-02 21:45:07.378 HD Request # 32 | Completion time: 1s | 2020-06-02 21:45:07.381 HD Request # 32 | Intraday data download complete for YMM20_FUT_CBOT. Unique request ID: 31 | 2020-06-02 21:45:07.381 Removing historical data download ID 31. | 2020-06-02 21:45:07.381 Real-time Intraday chart data file updates started for YMM20_FUT_CBOT | 2020-06-02 21:45:07.381 Intraday chart data file opened for YMM20_FUT_CBOT | 2020-06-02 21:45:07.381 HD Request # 32 | Enabling Intraday chart updating for symbol. | 2020-06-02 21:45:07.381 Triggering next historical data download in queue. | 2020-06-02 21:45:07.381 HD Request # 33 | Downloading Intraday chart data for GCM20_FUT_COMEX to the file GCM20_FUT_COMEX.scid. Service: comex | 2020-06-02 21:45:07.381 HD Request # 33 | Download start date-time: 2020-06-02 19:47:42.000 | 2020-06-02 21:45:07.381 HD Request # 33 | Using server: ds23.sierracharts.com port 10149 | 2020-06-02 21:45:07.382 Socket (5) | Creating socket. | 2020-06-02 21:45:07.382 Socket (5) | Connecting to IP: 216.1.90.130. | 2020-06-02 21:45:07.382 Socket (4) | Socket gracefully closed by remote side. | 2020-06-02 21:45:07.482 Socket (4) | Closed. | 2020-06-02 21:45:07.482 Chart #18 has tagged chart #4 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 21:45:07.612 HD Request # 33 | Setting DTC encoding to Binary VLS | 2020-06-02 21:45:07.614 HD Request # 33 | Sending historical data logon request message. | 2020-06-02 21:45:07.614 HD Request # 33 | Requesting Intraday data. Start date-time: 2020-06-02 19:47:42. Record interval: 0. Symbol: GCM20 | 2020-06-02 21:45:07.727 HD Request # 33 | Decompressing data. | 2020-06-02 21:45:07.839 HD Request # 33 | Receiving Intraday data for GCM20_FUT_COMEX starting at 2020-06-02 19:47:42 | 2020-06-02 21:45:07.839 Socket (5) | CloseSocket call. | 2020-06-02 21:45:07.839 Socket (5) | Shutdown started. Waiting for graceful close. | 2020-06-02 21:45:07.839 Historical data download thread signaled to stop. | 2020-06-02 21:45:07.847 HD Request # 33 | Received 2 records from 2020-06-02 19:47:42.000 to 2020-06-02 19:47:42.001 (0.0 seconds) and wrote 0 records for GCM20_FUT_COMEX | 2020-06-02 21:45:07.847 HD Request # 33 | Completion time: 0s | 2020-06-02 21:45:07.847 HD Request # 33 | Intraday data download complete for GCM20_FUT_COMEX. Unique request ID: 32 | 2020-06-02 21:45:07.847 Removing historical data download ID 32. | 2020-06-02 21:45:07.847 Real-time Intraday chart data file updates started for GCM20_FUT_COMEX | 2020-06-02 21:45:07.847 Intraday chart data file opened for GCM20_FUT_COMEX | 2020-06-02 21:45:07.847 HD Request # 33 | Enabling Intraday chart updating for symbol. | 2020-06-02 21:45:07.847 Triggering next historical data download in queue. | 2020-06-02 21:45:07.847 HD Request # 34 | Downloading Intraday chart data for ZBM20_FUT_CBOT to the file ZBM20_FUT_CBOT.scid. Service: cbot | 2020-06-02 21:45:07.847 HD Request # 34 | Download start date-time: 2020-06-02 21:29:35.000 | 2020-06-02 21:45:07.848 HD Request # 34 | Using server: ds21.sierracharts.com port 10150 | 2020-06-02 21:45:07.848 Socket (4) | Creating socket. | 2020-06-02 21:45:07.848 Socket (4) | Connecting to IP: 216.1.90.129. | 2020-06-02 21:45:07.848 Socket (5) | Socket gracefully closed by remote side. | 2020-06-02 21:45:07.950 Socket (5) | Closed. | 2020-06-02 21:45:07.950 HD Request # 34 | Setting DTC encoding to Binary VLS | 2020-06-02 21:45:08.061 HD Request # 34 | Sending historical data logon request message. | 2020-06-02 21:45:08.061 ESM20_FUT_CME [CBV][M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: CHT Last.Cht | 2020-06-02 21:45:08.105 HD Request # 34 | Requesting Intraday data. Start date-time: 2020-06-02 21:29:35. Record interval: 0. Symbol: ZBM20 | 2020-06-02 21:45:08.165 Chart #9 has tagged chart #4 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 21:45:08.213 HD Request # 34 | Decompressing data. | 2020-06-02 21:45:08.269 HD Request # 34 | Receiving Intraday data for ZBM20_FUT_CBOT starting at 2020-06-02 21:29:35 | 2020-06-02 21:45:08.269 Socket (4) | CloseSocket call. | 2020-06-02 21:45:08.270 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-06-02 21:45:08.270 Historical data download thread signaled to stop. | 2020-06-02 21:45:08.270 HD Request # 34 | Timestamp of first Intraday data file record written: 2020-06-02 21:32:49 | 2020-06-02 21:45:08.270 HD Request # 34 | Received 3 records from 2020-06-02 21:29:35.000 to 2020-06-02 21:32:49.000 (3.2 minutes) and wrote 1 record for ZBM20_FUT_CBOT | 2020-06-02 21:45:08.270 HD Request # 34 | Completion time: 1s | 2020-06-02 21:45:08.273 HD Request # 34 | Intraday data download complete for ZBM20_FUT_CBOT. Unique request ID: 33 | 2020-06-02 21:45:08.273 Removing historical data download ID 33. | 2020-06-02 21:45:08.273 Real-time Intraday chart data file updates started for ZBM20_FUT_CBOT | 2020-06-02 21:45:08.273 Intraday chart data file opened for ZBM20_FUT_CBOT | 2020-06-02 21:45:08.273 HD Request # 34 | Enabling Intraday chart updating for symbol. | 2020-06-02 21:45:08.273 Triggering next historical data download in queue. | 2020-06-02 21:45:08.273 Chart #7 has tagged chart #4 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 21:45:08.281 Opened cached Intraday file: C:\SierraChart\Data\YMM20_FUT_CBOT.scid. Thread ID: 10400 | 2020-06-02 21:45:08.312 Socket (4) | Socket gracefully closed by remote side. | 2020-06-02 21:45:08.375 Socket (4) | Closed. | 2020-06-02 21:45:08.375 ESM20_FUT_CME [CBV][M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: CHT Last.Cht | 2020-06-02 21:45:08.617 Opened cached Intraday file: C:\SierraChart\Data\GCQ20_FUT_COMEX.scid. Thread ID: 10400 | 2020-06-02 21:45:09.838 Opened cached Intraday file: C:\SierraChart\Data\ADV-SP.scid. Thread ID: 3024 | 2020-06-02 21:45:10.460 |
[2020-06-02 20:03:27] |
We see the problem: Allow Support for Sierra Chart Data Feeds is disabled. | 2020-06-02 21:39:07.536 Enable Global Settings >> Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds. And then reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-02 20:03:55
[2020-06-02 20:21:52] |
Well now it doesnt show as delayed, but nothing move at all. All connected seems good. but no move..
[2020-06-02 20:23:41] |
Software version: 2115 64-bit | 2020-06-02 22:22:02.903 Primary Thread ID: 6644 | 2020-06-02 22:22:02.903 Enabled for: Advanced Features 2. | 2020-06-02 22:22:02.903 Enabled for: Sierra Chart Historical Data Service. | 2020-06-02 22:22:02.903 Enabled for: Denali Real-Time Exchange Data Feed. | 2020-06-02 22:22:02.903 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-06-02 22:22:02.903 Enabled for exchange2: CME | 2020-06-02 22:22:02.903 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-06-02 22:22:02.903 Current selected Data/Trading service: SC Futures Order Routing/Data | 2020-06-02 22:22:02.903 Custom symbol settings values: disabled | 2020-06-02 22:22:02.903 Chart Update Interval: 500 | 2020-06-02 22:22:02.903 Intraday Data Storage Time Unit: 0 | 2020-06-02 22:22:02.903 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2020-06-02 22:22:02.903 2020-06-02 22:22:02 Local computer time | 2020-06-02 22:22:02.903 2020-06-02 20:22:02 Local computer time in UTC | 2020-06-02 22:22:02.903 2020-06-02 22:22:02 Local computer time in SC Time Zone | 2020-06-02 22:22:02.903 2020-06-02 19:25:28 Server time in UTC | 2020-06-02 22:22:02.903 Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-06-02 22:22:02.903 Program path: C:\SierraChart\ | 2020-06-02 22:22:02.903 Data Files path: C:\SierraChart\Data\ | 2020-06-02 22:22:02.903 OS Version Number: 10.0 | 2020-06-02 22:22:02.903 Locale Setting: C | 2020-06-02 22:22:02.903 Allowed protected custom studies: | 2020-06-02 22:22:02.903 Opened cached Intraday file: C:\SierraChart\Data\ZBM20_FUT_CBOT.scid. Thread ID: 9032 | 2020-06-02 22:22:20.703 Added historical Intraday data request for ESM20_FUT_CME to the queue. | 2020-06-02 22:22:28.701 Intraday data recording state for symbol ESM20_FUT_CME is set to download 'Pending'. | 2020-06-02 22:22:28.701 Triggering next historical data download in queue. | 2020-06-02 22:22:28.701 HD Request # 71 | Downloading Intraday chart data for ESM20_FUT_CME to the file ESM20_FUT_CME.scid. Service: cme | 2020-06-02 22:22:28.701 HD Request # 71 | Download start date-time: 2020-06-02 21:40:14.013 | 2020-06-02 22:22:28.702 HD Request # 71 | Disabling Intraday chart updating for symbol. | 2020-06-02 22:22:28.702 HD Request # 71 | Using server: ds21.sierracharts.com port 10149 | 2020-06-02 22:22:28.702 Socket (6) | Creating socket. | 2020-06-02 22:22:28.702 Socket (6) | Connecting to IP: 216.1.90.129. | 2020-06-02 22:22:28.702 HD Request # 71 | Setting DTC encoding to Binary VLS | 2020-06-02 22:22:28.921 HD Request # 71 | Sending historical data logon request message. | 2020-06-02 22:22:28.921 HD Request # 71 | Requesting Intraday data. Start date-time: 2020-06-02 21:40:14. Record interval: 0. Symbol: ESM20 | 2020-06-02 22:22:29.467 HD Request # 71 | Decompressing data. | 2020-06-02 22:22:29.574 HD Request # 71 | Receiving Intraday data for ESM20_FUT_CME starting at 2020-06-02 21:40:14 | 2020-06-02 22:22:29.806 HD Request # 71 | Truncating file to starting date-time of 2020-06-02 21:40:14.013 | 2020-06-02 22:22:29.806 HD Request # 71 | Timestamp of first Intraday data file record written: 2020-06-02 21:40:14 | 2020-06-02 22:22:30.131 Socket (6) | CloseSocket call. | 2020-06-02 22:22:30.232 Socket (6) | Shutdown started. Waiting for graceful close. | 2020-06-02 22:22:30.232 Historical data download thread signaled to stop. | 2020-06-02 22:22:30.244 HD Request # 71 | Received 76292 records from 2020-06-02 21:40:14.000 to 2020-06-02 22:14:59.053 (34.8 minutes) and wrote 76279 records for ESM20_FUT_CME | 2020-06-02 22:22:30.244 HD Request # 71 | Completion time: 2s | 2020-06-02 22:22:30.248 HD Request # 71 | Intraday data download complete for ESM20_FUT_CME. Unique request ID: 70 | 2020-06-02 22:22:30.248 Removing historical data download ID 70. | 2020-06-02 22:22:30.248 Real-time Intraday chart data file updates started for ESM20_FUT_CME | 2020-06-02 22:22:30.248 Intraday chart data file opened for ESM20_FUT_CME | 2020-06-02 22:22:30.248 HD Request # 71 | Enabling Intraday chart updating for symbol. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M] 5 Min #15 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M] #3 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M] #6 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M] #7 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M] #9 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M] #16 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M] #19 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M] #1 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M] #20 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M]/MESM20_FUT_CME[M] 30 Min #13 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M] Rev. 4t #14 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M]/MESM20_FUT_CME[M] Rev. 4t #18 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M]/MESM20_FUT_CME[M] 5 Min #25 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M] 5 Min #2 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M] 2 Sec #10 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] 15 Min #12 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] Rev. 4t #17 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CV][M] Rev. 4t #4 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CV][M] Rev. 4t #8 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] Rev. 4t #23 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] Rev. 4t #21 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M] 20 Sec #5 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] #17 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CV][M] Rev. 4t #14 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] Rev. 5t #23 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] Rev. 4t #24 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] 30 Min #3 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] 30 Min #13 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] #15 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] 1 Min #10 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] 1 Min #20 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] 10 Min #16 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] 1 Min #4 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] 30 Min #12 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] 30 Min #25 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] 15 Min #1 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME [CBV][M] Rev. 4t #5 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 ESM20_FUT_CME[M] 2 Sec #26 | Flagging to reload Intraday data on download completion. | 2020-06-02 22:22:30.248 Triggering next historical data download in queue. | 2020-06-02 22:22:30.248 Socket (6) | Socket gracefully closed by remote side. | 2020-06-02 22:22:30.339 Socket (6) | Closed. | 2020-06-02 22:22:30.339 ESM20_FUT_CME [CV][M] Rev. 4t #8 | Reloading chart. | 2020-06-02 22:22:30.613 ESM20_FUT_CME [CBV][M] 30 Min #12 | Reloading chart. | 2020-06-02 22:22:30.631 ESM20_FUT_CME [CBV][M] Rev. 4t #17 | Reloading chart. | 2020-06-02 22:22:30.651 ESM20_FUT_CME[M] #20 | Reloading chart. | 2020-06-02 22:22:30.672 ESM20_FUT_CME[M] #1 | Reloading chart. | 2020-06-02 22:22:30.678 ESM20_FUT_CME [CBV][M] 30 Min #13 | Reloading chart. | 2020-06-02 22:22:30.682 ESM20_FUT_CME [CBV][M] 30 Min #3 | Reloading chart. | 2020-06-02 22:22:30.707 ESM20_FUT_CME [CBV][M] 1 Min #20 | Reloading chart. | 2020-06-02 22:22:30.725 ESM20_FUT_CME[M] 5 Min #2 | Reloading chart. | 2020-06-02 22:22:30.743 ESM20_FUT_CME[M] #6 | Reloading chart. | 2020-06-02 22:22:30.748 ESM20_FUT_CME[M] 20 Sec #5 | Reloading chart. | 2020-06-02 22:22:30.774 ESM20_FUT_CME[M] 2 Sec #10 | Reloading chart. | 2020-06-02 22:22:30.795 ESM20_FUT_CME [CBV][M] 1 Min #10 | Reloading chart. | 2020-06-02 22:22:30.799 ESM20_FUT_CME[M] #7 | Reloading chart. | 2020-06-02 22:22:30.832 ESM20_FUT_CME[M] #3 | Reloading chart. | 2020-06-02 22:22:30.840 ESM20_FUT_CME[M] 5 Min #15 | Reloading chart. | 2020-06-02 22:22:30.845 ESM20_FUT_CME [CBV][M] 1 Min #4 | Reloading chart. | 2020-06-02 22:22:30.861 ESM20_FUT_CME [CBV][M] #15 | Reloading chart. | 2020-06-02 22:22:30.981 Loading market depth data. | 2020-06-02 22:22:31.094 ESM20_FUT_CME [CBV][M] 15 Min #12 | Reloading chart. | 2020-06-02 22:22:31.222 Loading market depth data. | 2020-06-02 22:22:31.297 ESM20_FUT_CME [CBV][M] Rev. 4t #24 | Reloading chart. | 2020-06-02 22:22:31.308 ESM20_FUT_CME [CBV][M] 30 Min #25 | Reloading chart. | 2020-06-02 22:22:31.334 ESM20_FUT_CME[M] 2 Sec #26 | Reloading chart. | 2020-06-02 22:22:31.364 ESM20_FUT_CME[M]/MESM20_FUT_CME[M] 5 Min #25 | Reloading chart. | 2020-06-02 22:22:31.490 Chart #10 has tagged chart #14 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 22:22:31.493 Chart #20 has tagged chart #14 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 22:22:31.494 ESM20_FUT_CME [CBV][M] #17 | Reloading chart. | 2020-06-02 22:22:31.502 ESM20_FUT_CME [CBV][M] Rev. 4t #5 | Reloading chart. | 2020-06-02 22:22:31.866 ESM20_FUT_CME[M]/MESM20_FUT_CME[M] Rev. 4t #18 | Reloading chart. | 2020-06-02 22:22:31.896 ESM20_FUT_CME [CBV][M] Rev. 4t #21 | Reloading chart. | 2020-06-02 22:22:31.915 ESM20_FUT_CME [CV][M] Rev. 4t #4 | Reloading chart. | 2020-06-02 22:22:32.042 ESM20_FUT_CME [CBV][M] Rev. 4t #23 | Reloading chart. | 2020-06-02 22:22:32.075 ESM20_FUT_CME [CBV][M] Rev. 5t #23 | Reloading chart. | 2020-06-02 22:22:32.103 Loading market depth data. | 2020-06-02 22:22:32.190 ESM20_FUT_CME[M] Rev. 4t #14 | Reloading chart. | 2020-06-02 22:22:32.305 ESM20_FUT_CME[M] #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-02 22:22:32.311 ESM20_FUT_CME [CBV][M] 15 Min #1 | Reloading chart. | 2020-06-02 22:22:32.352 ESM20_FUT_CME [CBV][M] 10 Min #16 | Reloading chart. | 2020-06-02 22:22:32.379 Chart #3 has tagged chart #14 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 22:22:32.529 ESM20_FUT_CME[M] #19 | Reloading chart. | 2020-06-02 22:22:32.531 ESM20_FUT_CME[M] #9 | Reloading chart. | 2020-06-02 22:22:32.536 ESM20_FUT_CME [CV][M] Rev. 4t #14 | Reloading chart. | 2020-06-02 22:22:32.544 ESM20_FUT_CME[M]/MESM20_FUT_CME[M] 30 Min #13 | Reloading chart. | 2020-06-02 22:22:32.572 ESM20_FUT_CME[M] #16 | Reloading chart. | 2020-06-02 22:22:32.577 Loaded depth data records for ESM20_FUT_CME 2020-06-02 from 2020-06-02 14:41:59 to 2020-06-02 22:14:59. | 2020-06-02 22:22:33.177 Loaded depth data records for ESM20_FUT_CME 2020-06-02 from 2020-06-02 14:41:59 to 2020-06-02 22:14:59. | 2020-06-02 22:22:33.547 Loading market depth data. | 2020-06-02 22:22:33.623 Chart #24 has tagged chart #14 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 22:22:33.669 Chart #24 has tagged chart #5 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 22:22:33.669 Chart #10 has tagged chart #4 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 22:22:33.730 Chart #10 has tagged chart #8 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 22:22:33.730 Loaded depth data records for ESM20_FUT_CME 2020-06-02 from 2020-06-02 14:41:59 to 2020-06-02 22:14:59. | 2020-06-02 22:22:34.460 Loading market depth data. | 2020-06-02 22:22:34.477 Chart #23 has tagged chart #14 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 22:22:34.576 Loading market depth data. | 2020-06-02 22:22:34.789 Loading market depth data. | 2020-06-02 22:22:34.893 Loading market depth data. | 2020-06-02 22:22:35.233 Loading market depth data. | 2020-06-02 22:22:36.224 Loading market depth data. | 2020-06-02 22:22:36.359 ESM20_FUT_CME[M] 5 Min #15 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-02 22:22:36.946 Loading market depth data. | 2020-06-02 22:22:37.120 Loaded depth data records for ESM20_FUT_CME 2020-06-02 from 2020-06-02 15:30:00 to 2020-06-02 22:14:59. | 2020-06-02 22:22:37.682 Loaded depth data records for ESM20_FUT_CME 2020-06-02 from 2020-06-02 14:41:59 to 2020-06-02 22:14:59. | 2020-06-02 22:22:38.909 ESM20_FUT_CME[M]/MESM20_FUT_CME[M] 30 Min #13 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-02 22:22:39.619 Loaded depth data records for ESM20_FUT_CME 2020-06-02 from 2020-06-02 14:41:59 to 2020-06-02 22:14:59. | 2020-06-02 22:22:40.421 Loaded depth data records for ESM20_FUT_CME 2020-06-02 from 2020-06-02 14:41:59 to 2020-06-02 16:15:01. | 2020-06-02 22:22:40.475 Loaded depth data records for ESM20_FUT_CME 2020-06-02 from 2020-06-02 14:41:59 to 2020-06-02 22:14:59. | 2020-06-02 22:22:40.482 ESM20_FUT_CME[M]/MESM20_FUT_CME[M] Rev. 4t #18 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-02 22:22:40.843 Loaded depth data records for ESM20_FUT_CME 2020-06-02 from 2020-06-02 14:41:59 to 2020-06-02 22:14:59. | 2020-06-02 22:22:40.943 Loaded depth data records for ESM20_FUT_CME 2020-06-02 from 2020-06-02 14:41:59 to 2020-06-02 22:14:59. | 2020-06-02 22:22:41.049 Loaded depth data records for ESM20_FUT_CME 2020-06-02 from 2020-06-02 14:41:59 to 2020-06-02 22:14:59. | 2020-06-02 22:22:41.245 Chart #23 has tagged chart #4 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 22:22:41.514 Chart #23 has tagged chart #8 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 22:22:41.514 Chart #25 has tagged chart #14 for full recalculation. Chartbook: CHT Last.Cht | 2020-06-02 22:22:41.543 ESM20_FUT_CME[M] #19 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-02 22:22:44.368 ESM20_FUT_CME[M] #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-02 22:22:51.490 Loading market depth data. | 2020-06-02 22:22:51.858 ESM20_FUT_CME[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-02 22:22:52.589 Loaded depth data records for ESM20_FUT_CME 2020-06-02 from 2020-06-02 08:41:59 to 2020-06-02 16:14:59. | 2020-06-02 22:22:53.178 ESM20_FUT_CME[M] 20 Sec #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-02 22:22:53.181 ESM20_FUT_CME[M]/MESM20_FUT_CME[M] 5 Min #25 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-02 22:22:53.810 Chart #25 has tagged chart #4 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 22:22:53.891 Chart #25 has tagged chart #8 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 22:22:53.891 Loading market depth data. | 2020-06-02 22:22:58.674 Loaded depth data records for ESM20_FUT_CME 2020-06-02 from 2020-06-02 14:41:59 to 2020-06-02 22:14:59. | 2020-06-02 22:22:59.835 Loading market depth data. | 2020-06-02 22:23:00.634 Loaded depth data records for ESM20_FUT_CME 2020-06-02 from 2020-06-02 14:41:59 to 2020-06-02 22:14:59. | 2020-06-02 22:23:01.757 ESM20_FUT_CME[M] #20 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-02 22:23:01.773 Chart #20 has tagged chart #8 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 22:23:01.844 ESM20_FUT_CME[M] #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-02 22:23:02.615 Chart #3 has tagged chart #4 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 22:23:02.667 Chart #3 has tagged chart #8 for full recalculation. Chartbook: SP500.Cht | 2020-06-02 22:23:02.667 ESM20_FUT_CME[M] #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-02 22:23:07.011 ESM20_FUT_CME[M] #16 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-02 22:23:08.262 ESM20_FUT_CME[M] Rev. 4t #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-02 22:23:21.091 ESM20_FUT_CME [CV][M] Rev. 4t #8 | Performing a full recalculation because it has been tagged. Chartbook: SP500.Cht | 2020-06-02 22:23:22.663 ESM20_FUT_CME [CV][M] Rev. 4t #4 | Performing a full recalculation because it has been tagged. Chartbook: SP500.Cht | 2020-06-02 22:23:23.064 Opened cached Intraday file: C:\SierraChart\Data\GCM20_FUT_COMEX.scid. Thread ID: 9032 | 2020-06-02 22:23:26.652 |
[2020-06-02 22:38:05] |
You were looking at the chart at the time the market was closed. It was closed at 22:23 Central European Time.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-02 22:38:14
[2020-06-03 07:32:00] |
User303735 - Posts: 9 |
Are you telling me that this data only works in RTH time???? Because that is weird...
[2020-06-03 07:57:48] |
No, the market was closed for a period of 15 minutes at that time. Are you receiving the real-time data now? That is what counts.
[2020-06-03 17:21:13] |
Actually it works :D thank you so much for your patience and help
