Date/Time: Tue, 16 Apr 2024 17:29:42 +0000
2nd symbol in chart
View Count: 1488
[2014-01-24 11:18:36]
AKR - Posts: 523
Is there an other way to get a second/third symbol (in my case A/D line and Tick) to a chart? can (should) be in a separate chart region?
like in link below this would mean always to keep the other symbols open in a different chart, right?
https://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#OverlayingMultipleSymbols
am also happy with answers by other users.
thx !!
[2014-01-24 11:32:14]
AKR - Posts: 523
well guess not, as I found also this:
https://www.sierrachart.com/index.php?l=doc/helpdetails66.html#h66.4
but can anybody tell me how I can get rid of the bars in non NYSE times? like in the image blow in the time before 15.30 (which is my time for opening of NYSE).
Thx again!
http://www.sierrachart.com/image.php?l=1390563023206.png
[2014-01-24 12:10:56]
AKR - Posts: 523
one more question:
how can I get a line on ZERO on the A/D line, separating + from -
[2014-01-24 12:25:40]
AKR - Posts: 523
found the line already, should search before asking ... sorry.
[2014-01-25 02:20:48]
When overlaying price bars from another chart, to avoid the filler bars use the Study/Price Overlay study.
[2014-01-27 13:17:29]
AKR - Posts: 523
great !! you´re the best.
can you give me a hint why the bar at 6.45 shows up??
http://www.sierrachart.com/image.php?l=1390828590617.png
[2014-01-27 16:47:23]
Most probably because there is a 6:45 bar from the source chart you are overlaying the study from.
