Date/Time: Thu, 25 Apr 2024 07:51:36 +0000
problem with DVP and peaks and valley
View Count: 1451
[2014-01-23 20:53:24] |
chris12 - Posts: 51 |
HI SC when i display "peaks and valley" for my DVP, a bug occur with the message "An unhandled exception was caught in c_chart::windowproc. message: 15, wparam: 0, Iparam:0 2014-01-23 21:18:27 " and the DVP disappear, the tape flashes... What is the problem ?? |
Capture d’écran 2014-01-23 à 21.19.20.png / V - Attached On 2014-01-23 20:37:30 UTC - Size: 10.69 KB - 371 views |
[2014-01-23 21:16:26] |
Could you provide us a Chartbook that contains one chart with the study configured as you are using it before you enable Peaks and Valleys so we can test this. Here are the instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-24 09:43:23] |
here the chartbook with the charts named "month", "week" or "week2" with DVP thx |
DAXFUTURE.cht - Attached On 2014-01-24 09:31:14 UTC - Size: 3.53 MB - 367 views |
[2014-01-24 10:24:12] |
We cannot work with this Chartbook. It is freezing Sierra Chart when we try to open it because there is something about its settings causing an enormous number of calculations. It also contains numerous custom studies. It also contains multiple charts. We just need a Chartbook with one single chart. We need the most simple set up, which is just before you make a change that causes the problem. Otherwise we cannot help with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-28 08:37:48
[2014-01-24 11:51:37] |
OK i delete the customs studies and check
[2014-01-24 14:56:38] |
i deleted customs studies but the problem continue. give you 2 charts with DVP and problems |
Chartbook1.cht - Attached On 2014-01-24 14:48:45 UTC - Size: 144.41 KB - 400 views |
[2014-01-27 14:25:35] |
UP
[2014-01-27 21:12:20] |
COULD YOU TEST THE CHARTBOOK PLEASE THX |
[2014-01-28 08:47:18] |
After a while, your original Chartbook you posted, did open up for us. It just took a while and we did not encounter any problems. We are now testing the latest Chartbook you posted we have enabled Draw Peaks and Valleys for the two Volume By Price studies in one of the charts and we still do not encounter any exceptions. We will let it run for a while. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-28 21:24:10] |
on this chart book only one chart who bug too sometimes…i don't understand secondly, the date passed 19.12.13 to 30.12.13 |
Chartbook3.cht - Attached On 2014-01-28 21:22:10 UTC - Size: 141.89 KB - 387 views |
[2014-01-29 17:20:40] |
We are testing the Chartbook. So far we still see no exception. We will be reviewing the code to see if we can determine what the problem could be.
[2014-01-29 20:16:31] |
i had to delete peak and valley to be able to work with my chart book for the moment, thanks for your work.
[2014-01-30 01:41:05] |
We are going to be releasing version 1087 this evening. Please test it to see if that solves the problem.
