Date/Time: Sat, 20 Apr 2024 01:26:54 +0000
Infinity AT 5.5.4 Locking up
View Count: 996
[2014-01-23 04:01:02] |
armando21 - Posts: 2 |
Using AT 5.5.4 . It takes order entry. Works for a while but when I try to modify order (Bid Qty or Ask Qty), cancel or flatten the keys get sticky then the platform locks up and data feed stop. I m using Window 8. I use Sierra Charting. I can not log back on Infinity AT platform. Help! Thank You. |
[2014-01-23 04:40:42] |
Please contact your Infinity broker for help with this.
