Date/Time: Thu, 25 Apr 2024 02:31:59 +0000
Problem connecting to new account with AMP/TTnet and SC real time data
View Count: 1174
[2014-01-22 20:37:35] |
inthetrend - Posts: 33 Invalid SC Account Name. |
I have meticulously gone through your instructions/illustrations and can not figure out what is wrong or missing. I will attempt to attach log file to this, and two clips of the Data/Trade Service Settings windows. Software version: 1080 | 2014-01-22 13:11:04 Usage end date: 2014-02-22 | 2014-01-22 13:11:04 Enabled for: Sierra Chart Historical Data Service. | 2014-01-22 13:11:04 Enabled for: Sierra Chart Real-Time Market Data Feed. | 2014-01-22 13:11:04 Enabled for: CME with exchange fee trading waiver. | 2014-01-22 13:11:04 Received 1 data feed usernames. | 2014-01-22 13:11:04 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-01-22 13:11:04 Active service: AMP/TTNet | 2014-01-22 13:11:04 Time Zone: -07:00:00 (MST-07) | 2014-01-22 13:11:04 2014-01-22 13:11:04 Local computer clock time | 2014-01-22 13:11:04 2014-01-22 20:11:04 GMT time | 2014-01-22 13:11:04 2014-01-22 13:11:04 Time zone adjusted time | 2014-01-22 13:11:04 Time difference to server time: 54 seconds. | 2014-01-22 13:11:04 WARNING: Your computer's clock is off by 54 seconds. For help with this Date-Time issue, press the Send for Analysis button. | 2014-01-22 13:11:04 Program path: C:\SierraChart\ | 2014-01-22 13:11:04 Data Files path: C:\SierraChart\Data\ | 2014-01-22 13:11:04 OS Version Number: 6.2 | 2014-01-22 13:11:04 Checking for new symbol settings for ttamp | 2014-01-22 13:11:04 AMP/TTNet: Connecting. | 2014-01-22 13:11:09 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:11:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:11:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:11:09 AMP/TTNet: Disconnected. | 2014-01-22 13:11:09 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:11:09 AMP/TTNet: Connecting. | 2014-01-22 13:11:14 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:11:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:11:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:11:14 AMP/TTNet: Disconnected. | 2014-01-22 13:11:14 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:11:14 AMP/TTNet: Connecting. | 2014-01-22 13:11:19 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:11:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:11:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:11:19 AMP/TTNet: Disconnected. | 2014-01-22 13:11:19 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:11:19 AMP/TTNet: Connecting. | 2014-01-22 13:11:24 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:11:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:11:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:11:24 AMP/TTNet: Disconnected. | 2014-01-22 13:11:24 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:11:24 AMP/TTNet: Connecting. | 2014-01-22 13:11:29 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:11:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:11:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:11:29 AMP/TTNet: Disconnected. | 2014-01-22 13:11:29 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:11:29 AMP/TTNet: Connecting. | 2014-01-22 13:11:34 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:11:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:11:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:11:34 AMP/TTNet: Disconnected. | 2014-01-22 13:11:34 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:11:34 AMP/TTNet: Connecting. | 2014-01-22 13:11:39 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:11:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:11:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:11:39 AMP/TTNet: Disconnected. | 2014-01-22 13:11:39 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:11:39 AMP/TTNet: Connecting. | 2014-01-22 13:11:44 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:11:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:11:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:11:44 AMP/TTNet: Disconnected. | 2014-01-22 13:11:44 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:11:44 AMP/TTNet: Connecting. | 2014-01-22 13:11:49 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:11:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:11:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:11:49 AMP/TTNet: Disconnected. | 2014-01-22 13:11:50 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:11:50 AMP/TTNet: Connecting. | 2014-01-22 13:11:55 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:11:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:11:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:11:55 AMP/TTNet: Disconnected. | 2014-01-22 13:11:55 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:11:55 AMP/TTNet: Connecting. | 2014-01-22 13:12:00 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:12:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:12:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:12:00 AMP/TTNet: Disconnected. | 2014-01-22 13:12:00 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:12:00 AMP/TTNet: Connecting. | 2014-01-22 13:12:05 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:12:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:12:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:12:05 AMP/TTNet: Disconnected. | 2014-01-22 13:12:05 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:12:05 AMP/TTNet: Connecting. | 2014-01-22 13:12:10 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:12:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:12:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:12:10 AMP/TTNet: Disconnected. | 2014-01-22 13:12:10 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:12:10 AMP/TTNet: Connecting. | 2014-01-22 13:12:15 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:12:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:12:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:12:15 AMP/TTNet: Disconnected. | 2014-01-22 13:12:15 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:12:15 AMP/TTNet: Connecting. | 2014-01-22 13:12:20 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:12:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:12:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:12:20 AMP/TTNet: Disconnected. | 2014-01-22 13:12:20 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:12:20 AMP/TTNet: Connecting. | 2014-01-22 13:12:25 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:12:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:12:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:12:25 AMP/TTNet: Disconnected. | 2014-01-22 13:12:25 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:12:25 AMP/TTNet: Connecting. | 2014-01-22 13:12:30 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:12:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:12:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:12:30 AMP/TTNet: Disconnected. | 2014-01-22 13:12:30 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:12:30 AMP/TTNet: Connecting. | 2014-01-22 13:12:35 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:12:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:12:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:12:35 AMP/TTNet: Disconnected. | 2014-01-22 13:12:35 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:12:35 AMP/TTNet: Connecting. | 2014-01-22 13:12:40 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:12:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:12:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:12:40 AMP/TTNet: Disconnected. | 2014-01-22 13:12:40 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:12:40 AMP/TTNet: Connecting. | 2014-01-22 13:12:45 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:12:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:12:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:12:45 AMP/TTNet: Disconnected. | 2014-01-22 13:12:45 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:12:45 AMP/TTNet: Connecting. | 2014-01-22 13:12:50 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:12:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:12:50 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:12:50 AMP/TTNet: Disconnected. | 2014-01-22 13:12:50 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:12:50 AMP/TTNet: Connecting. | 2014-01-22 13:12:55 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:12:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:12:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:12:55 AMP/TTNet: Disconnected. | 2014-01-22 13:12:55 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:12:55 AMP/TTNet: Connecting. | 2014-01-22 13:13:00 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:13:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:13:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:13:00 AMP/TTNet: Disconnected. | 2014-01-22 13:13:00 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:13:00 AMP/TTNet: Connecting. | 2014-01-22 13:13:05 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:13:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:13:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:13:05 AMP/TTNet: Disconnected. | 2014-01-22 13:13:05 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:13:05 AMP/TTNet: Connecting. | 2014-01-22 13:13:10 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:13:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:13:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:13:10 AMP/TTNet: Disconnected. | 2014-01-22 13:13:10 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:13:10 AMP/TTNet: Connecting. | 2014-01-22 13:13:15 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:13:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:13:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:13:15 AMP/TTNet: Disconnected. | 2014-01-22 13:13:15 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:13:15 AMP/TTNet: Connecting. | 2014-01-22 13:13:20 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:13:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:13:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:13:20 AMP/TTNet: Disconnected. | 2014-01-22 13:13:20 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:13:20 AMP/TTNet: Connecting. | 2014-01-22 13:13:25 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:13:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:13:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:13:25 AMP/TTNet: Disconnected. | 2014-01-22 13:13:25 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:13:25 AMP/TTNet: Connecting. | 2014-01-22 13:13:30 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:13:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:13:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:13:30 AMP/TTNet: Disconnected. | 2014-01-22 13:13:30 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:13:30 AMP/TTNet: Connecting. | 2014-01-22 13:13:35 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:13:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:13:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:13:35 AMP/TTNet: Disconnected. | 2014-01-22 13:13:35 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:13:35 AMP/TTNet: Connecting. | 2014-01-22 13:16:35 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:16:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:16:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:16:35 AMP/TTNet: Disconnected. | 2014-01-22 13:16:35 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:16:35 AMP/TTNet: Connecting. | 2014-01-22 13:19:35 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:19:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:19:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:19:35 AMP/TTNet: Disconnected. | 2014-01-22 13:19:35 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:19:35 AMP/TTNet: Connecting. | 2014-01-22 13:22:35 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:22:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:22:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:22:35 AMP/TTNet: Disconnected. | 2014-01-22 13:22:35 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:22:35 AMP/TTNet: Connecting. | 2014-01-22 13:25:35 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:25:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:25:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:25:36 AMP/TTNet: Disconnected. | 2014-01-22 13:25:36 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:25:36 Current selected Data/Trading service: AMP/TTNet | 2014-01-22 13:26:34 AMP/TTNet: Connecting. | 2014-01-22 13:28:36 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:28:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:28:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:28:36 AMP/TTNet: Disconnected. | 2014-01-22 13:28:36 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:28:36 AMP/TTNet: Connecting. | 2014-01-22 13:31:36 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:31:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:31:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:31:36 AMP/TTNet: Disconnected. | 2014-01-22 13:31:36 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:31:36 AMP/TTNet: Connecting. | 2014-01-22 13:34:36 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:34:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:34:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:34:36 AMP/TTNet: Disconnected. | 2014-01-22 13:34:36 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:34:36 AMP/TTNet: Connecting. | 2014-01-22 13:37:36 Unable to connect to the TT Price Feed. A port number is required as part of the address. Set the port in File >> Data/Trade Service Settings in the format "server address:port". | 2014-01-22 13:37:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-22 13:37:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-22 13:37:36 AMP/TTNet: Disconnected. | 2014-01-22 13:37:36 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-01-22 13:37:36 |
Private File Attachment Deleted. Attachment Deleted. Attachment Deleted. Attachment Deleted. |
[2014-01-22 20:39:45] |
Here is the second screen shot
Private File Attachment Deleted. Attachment Deleted. |
[2014-01-22 20:45:36] |
1. When you specify the Server, the port number needs to have a : in front of it. Like this: 1.1.1.1:100 2. You need to specify the Sender Comp ID. Please ask your broker for this. 3. WARNING: Your computer's clock is off by 54 seconds. This will also prevent the connection. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-22 20:45:49
