Date/Time: Fri, 19 Apr 2024 15:12:58 +0000
Number Bars Arrow on Price
View Count: 1093
[2014-01-21 23:21:32] |
pse52 - Posts: 18 |
I think I have the settings correct (see attached) but I do not get the arrows on the open and close price
Number Bars Arrow on Price.png / V - Attached On 2014-01-21 23:20:17 UTC - Size: 236.07 KB - 374 views |
[2014-01-23 01:39:14] |
You also need to set the Open and Close Marker Column number as explained here: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#InputSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-24 01:59:55] |
We have updated the documentation to clarify this.
