Date/Time: Tue, 23 Apr 2024 17:05:37 +0000
Date/time is off
View Count: 626
[2020-05-14 12:56:33] |
SurfTrader - Posts: 68 |
Reset my comp today and reinstalled SC, the time is off on my charts, says its 12:45 when its 8:55. Tried 'set system date/time from server' and it gave me an error message. How do I fix this issue?
[2020-05-14 12:59:17] |
Ok i figured it out but it is still 10 min behind, and showing delayed on the tab. I started a previous thread about it. How do I fix the delayed data?
[2020-05-14 15:50:30] |
John - SC Support - Posts: 31044 |
The question in Post #2 has been answered here: Delayed Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-14 19:26:43] |
Im still noticing my NQ TPO futures chart is at showing 19:24 and globex TPO's after I changed the time zone to NY in global seetings. My ES futures is correct time 15:24 and correct TPO period. How do I fix this? |
[2020-05-14 20:19:34] |
Check the time zone for that chart: Time Zone Setting: Using Different Time Zone in Individual Charts And also check the Session Times for that chart also: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-14 22:30:31] |
Alright I think that fixed it. Thanks
