Date/Time: Thu, 28 Mar 2024 15:12:30 +0000
Spreadsheet Data
View Count: 990
[2014-01-20 15:47:13] |
User15451 - Posts: 27 |
Dear Support, I would like to export spreadsheet gears data with technical data from indicators. It must be simple yet it escapes me on how to do this from within Sierra. I see where i can do this for symbol data however not with Spreadsheet & Technical data. Thank you for your support |
[2014-01-20 16:32:28] |
Select File >> Save As when a Spreadsheet Window is active. There are multiple file formats you can choose from to save the data as.
