Date/Time: Sat, 20 Apr 2024 08:08:47 +0000
What is the symbol for a "QQQ" Chart?
View Count: 1604
[2014-01-19 20:35:49] |
User20200 - Posts: 38 |
Hey Guy's Trying to make a "QQQ" Chart and cannot find it in the drop down (Find Symbol)... Does it exsist? Advise Chuck |
[2014-01-19 22:27:50] |
What Data or Trading service are you using Sierra Chart with? This will be set in File >> Data/Trade Service Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-20 00:43:59] |
It says SERVICE (trading) and it's grayed out cannot change... I am in the Simulated Live Account! Does this help? Chuck |
[2014-01-20 00:54:40] |
Are you trading with TransAct or Infinity?
[2014-01-20 01:00:13] |
My chart and dome say Infinity AT? Chuck |
[2014-01-20 01:02:40] |
They are futures broker. Therefore, there is no equity data available. You will need a direct account to access this data: https://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
