Date/Time: Sat, 20 Apr 2024 05:43:37 +0000
Time on Chart
View Count: 1154
[2014-01-18 21:30:01] |
User16114 - Posts: 153 |
Is there a way to put the Time on a chart so when I "Replay Chart" the chart time is on the chart?
[2014-01-18 21:54:52] |
Yes. Just add the Time field through Global Settings >> Customize Chart Header.
