Date/Time: Fri, 19 Apr 2024 03:55:44 +0000
SMS Messages
View Count: 1209
[2014-01-18 14:11:00] |
flyboy615 - Posts: 56 |
Hi, Any chance that the SMS messaging feature will be back in the development schedule any time soon? I had been using a twitter based API but Twitter recently has changed the authentication requirements to require a secure connection and what I have is no longer viable. Rather then redevelop I was wonder if the SMS was a possibility? Thanks |
[2014-01-22 02:34:13] |
We do apologize for this. We have talked about adding this capability and is not particularly hard, but there is always something higher priority which gets in the way of us getting this done. It will get done. We are working hard to get all of the overdue development done.
[2014-06-23 14:28:07] |
namlem - Posts: 94 |
Hello SC team, I'm aware that you are extremely loaded with current tasks, but maybe you could provide a small update on the subject. |
[2014-06-24 10:17:27] |
We have not had time to work on this. But we should be getting to it soon.
[2014-09-26 08:20:49] |
Bob77 - Posts: 17 |
Any news on this? Thanks |
[2014-09-26 09:04:18] |
The development for SMS messages is done, but it is not active and requires a final technical review. We will try to get to this next week. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-02 01:29:03] |
user54342 - Posts: 38 |
Hello, I see SMS notification in 1992 version of Sierra. Is it working? How much it cost per message? How it works when my data provider has got Siearra for free for me(I am using Infinity brokers)? Thank you |
[2014-10-06 07:21:15] |
SMS messaging should be disabled. It has not officially been released. Not quite sure about pricing but should not be more than .10 USD per message. To use SMS messaging will require a direct Sierra Chart account that has an Additional Services Balance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
