Date/Time: Fri, 29 Mar 2024 06:50:15 +0000
T4 and bracket orders
View Count: 1541
[2014-01-16 21:11:38] |
User28286 - Posts: 24 |
I have Sierra using T4 data feed with Dorman. When I place a simple bracket order entry (with stop + target), where the stop & target orders are located? Exchange? T4 server? My PC? And where can I define that? Thanks! |
[2014-01-16 21:16:31] |
They are initially held on the Sierra Chart side until the parent order fills at which time they are with the exchange . The OCO is managed by the T4 server.
[2014-01-16 21:30:21] |
Nice, thanks! I have a follow-up question, though. When in Sierra I have entry + target + stop, what kind order type is that Stop order? Is it StopMarket or StopLimit with some offset to make sure it's not run over? |
[2014-01-16 22:28:43] |
You can choose through the Attached Orders interface on the Trade Window whether it is a Stop Market order or Stop-Limit order. If you choose Stop-Limit than the offset is set on the "Set" tab of the Trade Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-16 22:28:54
[2014-01-16 22:33:57] |
ok. But by default it is a StopMarket order, or...?
[2014-01-17 01:27:58] |
If the Attached Order as listed as "Stop" then it is a Stop market order.
