Date/Time: Fri, 19 Apr 2024 05:31:57 +0000
TOOL_TEXT - How to force the default font properties from global properties?
View Count: 998
[2014-01-16 17:24:52] |
ejtrader - Posts: 688 |
Hello SC Team - Is there any way to force the ACSIL drawn text to get the font properties from Global/Chart font/size/colors? At present - manually drawn text is taking the properties from these global/chart properties but ACSIL drawn text is NOT picking the font properties. Any way to force it or any functions available to get these values? Thanks Date Time Of Last Edit: 2014-01-16 17:25:19
SC_Text_Manual_ACSIL.jpg / V - Attached On 2014-01-16 17:24:46 UTC - Size: 5.17 KB - 354 views |
[2014-01-16 17:43:37] |
No. This is not supported. The Font properties need to be specified through the s_UseTool structure.
