Date/Time: Thu, 25 Apr 2024 00:50:16 +0000
order rejected
View Count: 1661
[2013-04-15 15:05:50] |
You will need to contact Trading Technologies about this. The text after "Info" is from the TT FIX Adapter.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-15 15:06:19
