Date/Time: Thu, 25 Apr 2024 07:28:12 +0000
Missing futures (CME) contracts in SC feed symbol lists
View Count: 1400
[2014-01-16 15:45:54] |
DEA1 - Posts: 47 |
Hello. I'm missing some contracts (6E, NQ) among some others in my symbol lists. I've tried manually requesting the symbol, i.e. changing ES-201403-GLOBEX to NQ-201403-GLOBEX and the chart loads, but the pricing is wrong (3605.3/5/8 instead of 3605.25/5/75). Also, there is no [M] after the symbol, so I assume the data is from IB not your servers? Not sure what problem is and why some symbols are missing in my list? Thanks
[2014-01-16 15:53:15] |
Sierra Chart - Max - Posts: 5596 |
You need to reset the Symbol Settings following the steps under Full Reset of Symbol Settings here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings After the symbols are reset and the list is repopulated, reopen the Charts through File >> Find Symbol. Sierra Chart Support Date Time Of Last Edit: 2014-01-16 15:54:20
[2014-01-16 16:16:52] |
DEA1 - Posts: 47 |
Which service do I select in the Global Symbol Settings (the current service says Interactive Brokers..do I need to change this to SC Exchange Data?)?
[2014-01-16 16:24:08] |
It should be set to Interactive Brokers. It is quite unusual to actually be missing symbols from File >> Find Symbol. For interactive brokers 6E=EUR. You should see NQ under Futures. If you are not getting the Sierra Chart data feed, then post a copy of the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-16 16:43:12
[2014-01-16 16:31:19] |
DEA1 - Posts: 47 |
All done and working fine. Thanks for help.
