Date/Time: Wed, 24 Apr 2024 22:14:08 +0000
info adding symbols OPEN E CRY
View Count: 1454
[2014-01-15 15:59:30] |
User44790 - Posts: 20 |
how to add symbols to the sierracharts from striker or SOL or OPEN E CRY I would like emini russell 2000... gold..silver..high grade cooper natural gas ..gasoline ..heating oil...crude oil CL thank you..Jaroslav |
[2014-01-15 17:19:28] |
We do not know what is meant by "striker or SOL". All of these symbols are already supported with Open E Cry. You should see them in File >> Find Symbol. If not update Symbol Settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-15 18:19:57] |
Hello.... I dont know how to get symbols from OEC trader to sierra ..can you give me step by step instruction?? thank you... I need.... NYMEX crude oil....GCL heating oil ...GHO natural gas ...GNG RBOB gasoline....GRB COMEX copper...GHG gold ....GGC silver ...GSI paladium....GPA platinum...GPL emini russel 2000...RLM-M....ICE emini Nasdaq....NQ....CME emini SP.......ES......CME thank you..Jaroslav |
[2014-01-15 18:32:31] |
Restart Sierra Chart. Perform a Full Reset of the symbol settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings After this provide a copy of the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
