Date/Time: Thu, 25 Apr 2024 08:10:15 +0000
Measuring Tool
View Count: 1145
[2014-01-15 14:32:42] |
User94614 - Posts: 13 |
Is there a measuring tool to count the number of bars between two marked bars?
[2014-01-15 17:05:58] |
vegasfoster - Posts: 444 |
Tools>>Tools Configs>>Chart Calculator Config>>Labels Tab then select "Number of bars". Then use the chart calculator tool and it will show number of bars.
[2014-01-15 17:13:57] |
Yes. Use the Chart Calculator tool: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ChartCalculator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-21 12:45:03] |
Thanks, I got that working
