Date/Time: Fri, 29 Mar 2024 09:34:28 +0000
Volume Bars Are Not Being Created Correctly.
View Count: 1123
[2014-01-14 14:37:10] |
User94614 - Posts: 13 |
Volume Candles are not being correctly created. See attached incorrect image file. The candles are being repeated instead of being properly aggregated, those candles show gaps because the open in not at the previous candle's close. If a large block of stock trades that needs to be split between multiple candles, it should be done as in the attached sample image because the stock trades all at the same price. Could you please correct this problem? |
IncorrectVolumeBars.png / V - Attached On 2014-01-14 14:22:41 UTC - Size: 9.12 KB - 405 views SampleCandleDrawing.png / V - Attached On 2014-01-14 14:30:52 UTC - Size: 1.33 KB - 367 views |
[2014-01-14 19:19:41] |
Refer to help topic 47 about this subject: Http://www.sierrachart.com/index.php?l=doc/helpdetails47.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
