Date/Time: Fri, 19 Apr 2024 01:41:25 +0000
Historical Data Service Settings
View Count: 1005
[2014-01-14 09:30:54] |
user40663 - Posts: 54 |
Hi Currently using Sierra Chart 1070 and I have noticed when you go File > Data/Trade Service Settings > Historical Data Service Settings, there a no options now for a download time. I am getting a message saying "This window has settings for the download of historical daily data. This data is for historical charts, and not intraday charts". Not sure if this is the cause but it seems to make the previous daily bar disappear when i open Sierra until I click on the "delete and download data" option for each symbol. Examples before and after attached. Thanks |
QRB# Daily Before.JPG / V - Attached On 2014-01-14 09:30:42 UTC - Size: 88.86 KB - 382 views QRB# Daily After.JPG / V - Attached On 2014-01-14 09:30:50 UTC - Size: 88.22 KB - 410 views |
[2014-01-14 10:00:05] |
The common historical Daily data download time has been removed because every market has its own set of Session Times which control when the data should be downloaded. Historical Daily data is downloaded for a symbol when a new bar begins for the trading day and this is controlled according to the instructions here: http://www.sierrachart.com/index.php?l=doc/helpdetails12.html#h12.6 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-14 10:00:34
