Date/Time: Fri, 29 Mar 2024 05:35:45 +0000
moving average value
View Count: 999
[2014-01-13 21:43:43] |
User42397 - Posts: 19 |
This is a question with probably a very easy answer, but I am uninformed. When I pull up an intraday chart, say NQH4, for any time frame, daily, or hourly or whatever, and run a moving average on it (or any other analysis), the moving average line displays, but where do I find the actual value for the moving average on a given day? I'm looking through all the values across the chart on the top but none of them seems to be the moving average.
[2014-01-14 09:53:32] |
The best way to do this is with the Chart Values Tool: https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ChartValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-14 09:53:50
