Date/Time: Tue, 23 Apr 2024 15:54:13 +0000
IMPORTING OF MY OWN DATA FOR TRADING SIMULATION - no success
View Count: 1134
[2014-01-12 21:59:20] |
User14549 - Posts: 1 |
Today I tried to import my own data to Sierra Chart for trading simulation with following procedure and result: 1. FILE / Disconnect 2. Trying to import my own 1 min ES mini data in csv format from Nov 1997 to 25th Oct 2013 via EDIT / Import and Load Intraday Data 3. – sample of data format attached 4. Result – loaded only part of the data from only 26-09-2013 till 25-10-2013 (this is OK, my data end by this date) and not in 1 min format (see images of chart and copy of the log attached) Many thx for your help Ivan |
COPY OF THE LOG.docx - Attached On 2014-01-12 21:56:27 UTC - Size: 12.44 KB - 387 views ESZ3- 1min - sample of data format .csv - Attached On 2014-01-12 21:57:13 UTC - Size: 2.38 MB - 386 views Data import 1 - beginning of imported period.JPG / V - Attached On 2014-01-12 21:57:30 UTC - Size: 194.21 KB - 363 views Data import 2 - end of imported period.JPG / V - Attached On 2014-01-12 21:57:46 UTC - Size: 190.03 KB - 378 views |
[2014-01-13 09:27:02] |
The format for the Time field in the file is not correct. Refer to: https://www.sierrachart.com/index.php?l=doc/doc_TextCSVDataFormat.html#TimeFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
