Date/Time: Thu, 25 Apr 2024 23:11:51 +0000
zone of value area current day
View Count: 998
[2014-01-12 17:02:48] |
User45578 - Posts: 49 |
HI?i've Two computers one with Window 8 and the older Window7 i succed easly to put on my graph with W7 the current VAday and i get colorized zone between VAH and VAL with Trans Fill Bottom and Trans Fill Top but it is impossible to get it with window 8 is it the only reason?or am i doing a mistake somewhere THE setteings are the same of course Date Time Of Last Edit: 2014-01-12 17:04:15
[2014-01-15 05:07:47] |
What particular study are you using? The operating system is not going to matter. You should get the same result regardless as long as the study settings are the same between the two instances of it. You also need to check the transparency level setting in Global Settings >> Graphics Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
